RV.Net Open Roads Forum: Towing: porpoising????
Search only in Towing
Open Roads Forum  >  Towing
 > porpoising????
rode2nowhere
southern indiana
Posted: 05/06/12 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
I think its what my setup is doing, 2004 2500hd duramax. Pulling 35 foot 311bhs keystone sprinter. Have equalizer hitch setup. I think it is setup wrong, when driving I am getting a lot of rear tow vehicle bouncing up and down, no sway just bouncing. Trailer is 8200 pounds dry. I printed instructions out off net, but I used to have hitch on f150 4x4 and just put it on other truck. Dealer set it up and I guess you have to put more washers in there somewhere, special washers or what? thanks in advance
* This post was edited 06/14/12 06:54pm by rode2nowhere *
Golden_HVAC
Fulltime, CA, USA
Posted: 05/06/12 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
First you have to make sure that you don't have the dreaded quick release GMC hitch. One minute you are driving down the freeway with the trailer attached, the next it comes detached. So check carefully for cracks between where the square part meets up with the round thinwall tubing under the truck. If cracked, get rid of the 42 pound heat treated GMC hitch and install a 65 pound hitch that should have been there in the first place, with heavy duty thick wall square tubing.
Second, make sure that the hitch bars are not overtightened. If over tight, they will spring back and forth, like you mentioned in the post. You really don't need to transfer that much weight to the front axle to avoid steering issues, and the rear axle is stout enough to carry the hitch load.
Fred.
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/06/12 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
You got the wrong animal. It's a porpoise, not a dolphin.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
WyoTraveler
Northwest, Wyoming
Posted: 05/06/12 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, get rid of the factory hitch and buy a class V hitch. Only about $200 and well worth the upgrade.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
RCMAN46
NorthWest
Posted: 05/06/12 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Tongue weight? Have you checked it? Is the trailer level? Air bags on the truck?
CManley
Elk Grove, Ca
Posted: 05/06/12 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, sadly GM did us no favors with the hitch, you'll need to change it if it is OEM.
I had the same proposing problem from the day I bought My truck in 2005. I tried to address through WD Hitch set-up and could only get a marginal difference. I just change the shocks at 41k and solved my problem. I replaced the factory shocks with Monroe Reflex and also replaced the trailers shocks.
Now it is a smooth ride.......
2001 25dbs Tahoe TT, 2005 Chevrolet Silverado 2500 Duramax
Pictures
MitchF150
Washington, the State
Posted: 05/06/12 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Get rid of the OEM shocks if you haven't already done that.. Any aftermarket shocks will be better then OEM..
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
davisenvy
Franklin, NC
Posted: 05/06/12 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 07 Dmax with 80k on it. I replaced my shocks last week with Bilstein trying to get rid of the same thing you are. Alligator Performance has a set of 4 for $245 delivered. My old shocks could be compressed with two fingers and would not rebound when set on a work bench. They were completely shot. I haven't towed with the new shocks yet, but the truck definitely rides better. Took about 1hr to do the install with basic hand tools.
2007 GMC Sierra Classic 2500HD SLT,4x4,Crew, Duramax
2011 Keystone Sprinter 323bhs
Chuck&Gail
In the Colorado Mountains
Posted: 05/06/12 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Any good hardware store should have HARDENED washers for hitch.
Usual cause is tongue weight not adjusted to be 13 to 15% of ACTUAL MEASURED FULLY LOADED TT weight, or improperly adjusted Equalizer. Often too few washers, as you suspected.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
eric james
Sioux Falls, SD
Posted: 05/06/12 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Weight Distribution Hitch Set Up Instructions <-- read, watch videos and set up your hitch correctly.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
 > porpoising????
