RV.Net Open Roads Forum: Travel Trailers: GVWR
flathead92
Chandler AZ
Posted: 05/06/12 01:46pm Link  |  Print  |  Notify Moderator
My 2011 F150 Eco boost has a 7100# GVWR sticker on the door, However when I go to the Ford towing guide and look it up it says I can tow up to 9800# One of them numbers are wrong. right?
fla-gypsy
North Florida
Posted: 05/06/12 01:52pm Link  |  Print  |  Notify Moderator
The GVWR is the maximum your truck can weigh and is not indicative of the max tow rating.
sch911
Rochester Hills, MI
Posted: 05/06/12 01:53pm Link  |  Print  |  Notify Moderator
GVWR is how much your F-150 can weigh.
To figure your towing capacity you'll need the GCWR Gross COMBINED weigh rating.
Tow # = GCWR - The weight of your F-150
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
tls001
Mid-West
Both are correct, your truck by itself can weigh up to 7100lbs loaded, that is including you and passengers and any cargo. You can tow a trailer weighing up to 9800 lbs. The only real way to know whether or not you are staying below your weight limits are to go to a scale and weigh your truck alone and then with the trailer in tow. I believe there is a sticky on this forum that explains how to do this to get all the info you need.
skipnchar
Topeka or somewhere else
Posted: 05/06/12 03:07pm Link  |  Print  |  Notify Moderator
One has nothing to do with the other. GVWR is a safety number and your maximum trailer weight is a warranty issue.
HappyKayakers
Black River Falls WI
Posted: 05/06/12 03:19pm Link  |  Print  |  Notify Moderator
You also have to include the tongue weight of the hitched trailer in your truck weight.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
Ron Gratz
full time RVer
Posted: 05/06/12 04:25pm Link  |  Print  |  Notify Moderator
If you are using a weight distribution hitch, you don't have to include the entire tongue weight in the TV's GVW.
You only need to include the portion which actually is carried by the TV. That typically is a load equal to about 75% of the tongue weight.
Ron
APT
SE Michigan
Posted: 05/07/12 06:05am Link  |  Print  |  Notify Moderator
Additionally, the tow rating for your truck is not likely to mean RV tow rating. A 5000 pound travel trailer can put a half ton over some other limits/ratings with a large family and some camping gear in the bed. Look for another sticker on the driver's door jam for actual payload, called the Tire and Loading sticker. Typically in the 1500 pound range, subtract the estimated weight of your family, estimate for weight in the bed, and you are left with 600-1000 pounds for trailer tongue weight. You'll be happy if you stick to TT's under 6000 pounds dry.
2012 VW Passat TDI
