brysonhollar
NC
Good afternoon all,
Leaving the campground today while dumping, one of my grey tank handles just snapped into. It's the kind that has a plastic tee handle attached to a threaded aluminum rod. It broke about 10" back from the handle. Does anyone know if these can be replaced? If so, how hard is it and where do I buy a replacement handle? And to make matters worse, I have a sealed underbelly.
Thanks for the help
belairbrian
Alabama
The aluminum rod should un-thread from the valve. As long as part of the rod is still accessible a pair of vice grips should remove it.
TV 2003 Chevy 3500 Crew Cab Dually w Duramax/Allison
2005 Keystone Cougar 314 EFS
Reese 16K Slider Hitch, Prodigy BC, Delorme GPS
USAF Retired
Wind River
wyoming
I was able to purchase a metal handle from the RV dealer.
2003 GMC 2500HD 4x4 Duramax/Allison
2004 Jayco Jay Flight 25RKS
Equal-i-zer Hitch, 3502 Ultra Fab Tongue Jack
Twin Honda 2000i w/parallel kit
JJBIRISH
Butler, PA, USA
If the handle broke it can be replaced… if it’s the rod that broke I have never seen a replacement part for it…
Luckily it only cost a few dollars (under $10) to replace the whole valve and its so easy a caveman can do it…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
belairbrian
Alabama
Valterra sells the rod extensions in various lengths. Some use a slip over coupling with set screws to attach to the valves existing shaft.
You can download the Valterrs catalogs at their website.
brysonhollar
NC
Here's what I bought:
http://www.amazon.com/dp/B002N5J9HU/ref=pe_175190_21431760_A1_cs_sce_dp_1
Hopefully this will do the trick. I just hope I don't have to take down any of the underbelly.
j.p.f.
ga.
1/4-20 all thread rod cut to length will work, ugly, but it's only a drain handle.
JJBIRISH
Butler, PA, USA
On mine the rod doesn’t unscrew from the blade, it turns but doesn’t unscrew…
I assume that is the reason they don’t list it as a replacement part…
If the rod on his broke there isn’t much chance there’s enough left for the extension to hook to…
The best and maybe the only fix, is replacement of the valve… 2 or 3 trips to the hardware and RV store cost more than replacing the valve that only cost around 7 or 8 bucks to begin with… the extension if he gets it connected cost almost as much as the valve and has the propensity to pull/fall apart…
Jimmie2
Melbourne, FL
j.p.f. wrote: 1/4-20 all thread rod cut to length will work, ugly, but it's only a drain handle.
Exactly what I did only I covered the threaded rod with some electrical shrink tubing so that none of the threads would rub against the underbelly material. Put some Lock-Tite on the threads and the handle for added assurance. Works perfectly!
Jimmie
brysonhollar
NC
Believe it or not my fix was extremely simple. My rod was a two piece threaded rod. It broke about 1/2" before the threads. I took the rod out and re-threaded it and put it back on.
