tomkaren13
West Central Florida
We like to put up a sign with our name. We have used a hanger from a cheap flag but that did not work out well. Has anyone found or built a hanger or stand that is not expensive.
theoakman
Hereford, AZ, USA
We have been hanging ours on the king pin box, but you can't see it with the truck parked in front of the fiver.
I'm thinking of rebar or a plant or bird feeder hanger, cut down to 3 feet or so, then weld on a couple of bars so it's a "Y" shape. Or one longer bar to make a "T" shape. Also needs a short bar near the bottom so you can use you foot to push it into the ground.
A rawhide lace from each end of the sign would attach to the ends of the "Y" arms, or to the ends of the "T", this would keep it from spinning in the wind.
Maybe simpler, put a 90 degree bend in the hanger at the right height, cut it wide enough to hang the sign under. Like an inverted "L". Decorate to your liking.
Cya l8r,
the oakman
funny, I don't remember being absent minded
campinginthewoods
Central ILL
I use a small garden flag holder.....found mine at wal mart.
"Our family is a circle of love and strength.
With every birth and every union, the circle grows. Every joy shared adds more love.
Every crisis faced together makes the circle stronger. "
FunnyCamper
Southeastern
I hung a small cute sign on a tree once at the campsite because the nail was already there. I left it. and YUP I was ticked at myself
I want a name sign now but am worried it too will not come back with me.
I was thinking the msall garden flag holder would be ok also.
Dick_B
Palos Heights, IL USA
We hang our sign by string in the front window between the struts that hold up the cover.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
tomkaren13
campinginthewoods wrote: I use a small garden flag holder.....found mine at wal mart.
This is what we have used. But our sign is somewhat heavy for the flag holder. Need something heavier.
Wherever I happen to park
Get a Plant Stake or 2.. And a pair of corner brackets (L-Brackets) You want the ones that are flat.
You may need two plant stakes depending on your sign.
Cut a piece of stake, A bit longer than the sign.
now, hear the top of either the other stake, or the rest of the stake (Depending) mount the L, just use the top hole and center it on the side so it stick out a few inches below the top.
This is where the sign-length piece hooks up
Pictures I can draw if I must. NOTE, if you do it right, the sign length piece will "Flip" over the top and lie beside the ground stake for storage.
CincyGus
Cincinnati
I put two hooks in the top of our sign and it hangs from a Shepards Hook like you use in the garden.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
jms1123
Chatham, IL
Wish I had a picture of ours my DH made out of PVC pipe. Shaped like a cross. I had a sign made with our name on it and a light at the top-I imagine you could use a solar light now. Helps us identify our site when walking around the CG at night I believe a toilet flange is what he used on the bottom which is nice because you can then stake it in the ground. . He glued the top part and the bottom part seperately so it can come apart when we are ready to leave.
Jimmie2
Melbourne, FL
Made mine from PVC piping that was not glued for easy storage. Then I used a couple 4 foot rebar that I pound into the ground about a foot or two and slip the PVC over them for a stand. Makes for a nice sturdy sign post.
