RV.Net Open Roads Forum: General RVing Issues: St Tires VS LT Tires
 > St Tires VS LT Tires
Page of 8
JIMNLIN
out here
Posted: 05/09/12 07:52pm Link  |  Print  |  Notify Moderator
Please post where you get 7" or 7.5" wide zero offset trailer wheels for LT265/75R16 tires? Reliable tire stores should not mount a tire on a wheel that is narrower than the minimal width a tire manufacture calls for.
If you are running tires on the wrong rims that is your issue, however it is wrong for you to encourage others to follow you miss steps
Load carrying tires on our trucks and trailers work best when the treads width = the wheels width. Most 265 tires have 8"-8.5" wide tread. Mounting them on a 7"-7.5" wheel isn't a wise move from a load carrying perspective. The tire at those max pressures will cause the tread to ballon, and ride the centers.
On a race vehicle we can play around with the rim widths to accpmplish different results. No biggie however a load carrying wheel/tire is a whole different matter.
This from Dunlap; (a google has much more of the same info from other sources)
Dunlap
RIM WIDTH
Correct rim width ensures flex at the designed flex point in a tire sidewall for optimum tire performance.
If the rim is too narrow, the flex point moves toward the shoulder area, creating heat buildup in the shoulder, which reduces tire life and could result in failure.
If the rim is too wide, the flex point moves towards the rim area, causing heat buildup in the lower sidewall, which reduces tire life and could result in failure.
Within the acceptable range of rim widths, one can select wider or narrower rims than the measuring rim. Selection of a wider rim, from within the approved range, (T & RA tables) stiffens the sidewall and improves handling at the expense of handling. If carried too extreme, either too narrow or too wide of a rim, it can result in uneven tread/pavement contact pressure causing uneven wear and potentially reduced traction, or increased vulnerability to bead dis-lodgement.
'97 Park Avanue 28' 5er 11200 gvwr two slides
Snow_King
Gold Canyon, AZ
Posted: 05/09/12 08:11pm Link  |  Print  |  Notify Moderator
Dunlap
RIM WIDTH
Thanks for the knowledgeable post and reference. I have seen two or three posters in the last two years endorsing 265's for trailers which is not good. I have also seen them on 6.5 inch GM 2500hd rims and they really roll in at the rim/bead. I do not know how a knowledgeable tire tech would mount these on narrow rims. Tires are to expensive and important to be screwing around like this.
It is not right to miss lead others about tires.
Somewhere in a Fifth Wheel - Where it does not Snow
steelpony5555
Copperas Cove Texas
Posted: 05/09/12 09:55pm Link  |  Print  |  Notify Moderator
uhhhhh why go to all that cost and hassle to run a tire that should not be there when you can buy a Goodyear G614 that will handle the weight and run just fine. Why chance it just upgrade to G and live with it......
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
ExRocketScientist
Laurel, MD
Posted: 05/10/12 05:39am Link  |  Print  |  Notify Moderator
The 17.5 inch is not an oddball. It is a medium duty commercial truck tire that is far more available than the G614. The G614 is an RV thing and not commonly stocked. With the 17.5 inch tires, think "fleet supply" and "truck stop". Commercial trucks don't make money sitting parked. Because of that, there are a lot of businesses out there that make money by keeping them rolling. They can help you with tires when Walmart, Sears, and your local tire stores are all closed.
ERS
steelpony5555
Copperas Cove Texas
Posted: 05/10/12 07:18am Link  |  Print  |  Notify Moderator
I was talking about the 265/75/16 everyone is arguing about....
Dixie Flyer
Piedmont, SC 29673
Posted: 05/10/12 06:11pm Link  |  Print  |  Notify Moderator
This morning we stopped at the tire dealer and bought the 23580R16 load range E Tow Max Power King tire and had them mounted on the camper. We were on the road by 10:am and we got home at 6:30 this evening, everything is fine.
2012 Ford King Ranch F-350 Crew Cab Diesel
2011 Montana 3580RL
Wife Sue
Pets: Rainbow Bridge: Old Fella, Levi, Charlie. Others Suzie, Peaches, Hobo, Mama, Izzie
Old Fella Burke County Animal Rescue
steelpony5555
Copperas Cove Texas
Posted: 05/10/12 06:33pm Link  |  Print  |  Notify Moderator
Heartland owners
Power King complaints
More
I don't know,,,, but hope they work out for you....
Snow_King
Gold Canyon, AZ
Posted: 05/10/12 07:27pm Link  |  Print  |  Notify Moderator
Now that you are done with them, maybe someone on the forum that likes them will buy them from you! I think I read that one poster was going to buy a new set before summer.
Jarlaxle
New England
Posted: 05/10/12 09:08pm Link  |  Print  |  Notify Moderator
Dunlap
RIM WIDTH
AUUUUUUUUUUUUUUUUUUUUUUGH! Ye gods, people, please READ WHAT I HAVE POSTED and THINK! I am NOT, REPEAT NOT suggesting putting 265/75R16 tires on 6.5" wide wheels! I have never done so in this thread or anywhere else!
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
Jarlaxle
New England
Posted: 05/10/12 09:12pm Link  |  Print  |  Notify Moderator
Please read and respond to what I ACTUALLY TYPED, not what you want to think I typed. In the real world, a 17.5" tire is an oddball. It is used on a minuscule amount of vehicles. Been there and done that: getting one was often a day or more wait and ALWAYS expensive. Whereas, again, an LT265/75R16E is a dirt-common size, and is guaranteed to be IN STOCK at any tire shop.
Page of 8
