RV.Net Open Roads Forum: Tech Issues: accumulator
 > accumulator
jwblock
Sussex Wisconsin
Posted: 05/06/12 03:29pm Link  |  Print  |  Notify Moderator
How much air do you put in your accumulator tank? Just below the cut in pressure of the pump?
Old-Biscuit
Across the USA
Posted: 05/06/12 04:05pm Link  |  Print  |  Notify Moderator
Correct....
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
wolfe10
Yes. So if cut in PSI is 25, with system depressurized, inflate to 23 PSI.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
eHoefler
ozark mountains
Posted: 05/06/12 04:30pm Link  |  Print  |  Notify Moderator
2 PSI below cut in pressure.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
LTCLarry
Maggie Valley, NC
Posted: 05/16/12 08:40am Link  |  Print  |  Notify Moderator
Does this mean that you have to add air to the accumulator tank using an air pump or a compressor?
beemerphile1
I'm 57, I'm not a
Posted: 05/16/12 11:37am Link  |  Print  |  Notify Moderator
Yes unless you've got really strong lungs to blow into the Schrader valve!
Even if you are on the right track, you'll get run over if you just sit there.
- Will Rogers, American actor
LTCLarry
Maggie Valley, NC
Posted: 05/16/12 12:05pm Link  |  Print  |  Notify Moderator
I just asumed that they worked the same as the pressure tank on my well at home. I guess this is one mod I'll pass on. I do mostly CG style camping so unless I start doing a good bit of dry camping I don't need it.
Mootpoint
Somewhere in North America enjoying the life!
Posted: 05/16/12 12:17pm Link  |  Print  |  Notify Moderator
I have a father inlaw that would over inflate it!!
Nothing sucks more than that moment during an argument when you realize you're wrong.
mikestock
Vestavia Hills, AL, USA
Posted: 05/16/12 01:29pm Link  |  Print  |  Notify Moderator
The instructions that came with mine said precharge to 20 psi. 23 to 25 would probably be OK. I use a bicycle pump to keep from inflating too quickly.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
beemerphile1
I'm 57, I'm not a
Posted: 05/16/12 01:54pm Link  |  Print  |  Notify Moderator
You only set the pressure once. Mine has been in use for around six years without even checking the pressure. Once set you don't need to mess with it unless something changes.
 > accumulator
