RV.Net Open Roads Forum: Tech Issues: accumulator
 > accumulator
LTCLarry
Maggie Valley, NC
Posted: 05/17/12 08:39am Link  |  Print  |  Notify Moderator
beemerphile1 wrote:
LTCLarry wrote:
beemerphile1 wrote:
LTCLarry wrote:
wolfe10 wrote:
Yes. So if cut in PSI is 25, with system depressurized, inflate to 23 PSI.
Does this mean that you have to add air to the accumulator tank using an air pump or a compressor?
Yes unless you've got really strong lungs to blow into the Schrader valve!
I just asumed that they worked the same as the pressure tank on my well at home. I guess this is one mod I'll pass on. I do mostly CG style camping so unless I start doing a good bit of dry camping I don't need it.
You only set the pressure once. Mine has been in use for around six years without even checking the pressure. Once set you don't need to mess with it unless something changes.
Hey thanks....I was of course thinking I had to do it every time I took the TT out.....
jauguston
Bellingham, WA
Posted: 05/17/12 09:07am Link  |  Print  |  Notify Moderator
A FWIW about accumulators. I just upgraded to a Surflo 5.7 gpm pump and the instructions said if your system has a accumulator remove or disable it.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
LTCLarry
Maggie Valley, NC
Posted: 05/17/12 09:22am Link  |  Print  |  Notify Moderator
Jim
Interesting ....does it say WHY? I always like to know why.
jauguston
Bellingham, WA
Posted: 05/17/12 01:53pm Link  |  Print  |  Notify Moderator
No but they do have a phone.
Jim
pkunk
Questa, NM
Posted: 05/17/12 04:45pm Link  |  Print  |  Notify Moderator
Because it is a variable speed pump and comes on slow with the slightest flow. An acumulator tank would not do anything.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
Dutch_12078
Great Sacandaga Lake, NY
Posted: 05/17/12 06:56pm Link  |  Print  |  Notify Moderator
Jim
If you installed a Shurflo Extreme Smart Sensor 5.7 GPM pump, then I wouldn't suggest removing the accumulator tank. Adding a valve to temporarily disable it will allow you to use it again in the future. The Extreme pumps have been arguably one of the highest failure rate pumps Shurflo has ever produced.
* This post was edited 05/17/12 07:03pm by Dutch_12078 *
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
 > accumulator
