Neil benjamin
canada
Hi
my stock battery is a interstate start/deep battery about 2 years old
checked it and its in good shape . I would like to add a second battery and the dealership now carries interstate deep cycle . the salesperson told me its better than my original start/deep because its true deep cycle . Can i just add it or do i have to replace my original battery ? I am concerned about charging /discharging
Thanks
2007 jayco 23b
equalizer WDH
prodigy p3
2oldman
Winchester WA
It's generally not recommended to mix age/type, but i'm sure it'll work fine.
BFL13
Victoria, BC
Started with two 6s, added two 27DCs ("starting/deep-cycle")for four batteries in series parallel, got another 27DC two years later so went with three 27DCs and two 6s in a bank of 5, then later got four new 6s but still have the newer 27DC from before so sometimes I add that to the four 6s and still get a bank of 5.
In other words, ignore everybody and just do it!
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
garym114
Bluff Dale, Texas
Very unlikely it is a true deep cycle unless it is a 6v golf cart battery.
What is the model number of the battery?
Wherever I happen to park
2oldman wrote: It's generally not recommended to mix age/type, but i'm sure it'll work fine.
I will support that advice as well.. The major difference, from your point of view, is that a TRUE DEEP CYCLE (Which some here say do not exist) can survive an "OPPS" better than a starting battery.
What is an Opps? Say voltage less than 10. (For a 12 volt battery) That is a very deep discharge.
NOTE: that even with true deeep cycle, OPPS is not recommended.
the_armadillo
SE Texas
If you start/charge regularly, you will most likely not have much of an issue. However, during storage different battery types/ages will have different internal resistances and voltages and will discharge each other much quicker than identical batteries or a single battery will. If you isolate the two during storage then you remove this problem but should bring up to full charge individually prior to paralleling again.
BFL13
Victoria, BC
The_ armadillo is right on. You can discharge them all as a bank and get Peukert working for you. You can charge them all together while camping doing your 50-90s.
But do their 90-100s at home separately and check each's SG to make sure each gets truly full. After that I don't mind floating them all together to prevent self-discharge, but that depends on how long before the next rrip before they start stratifying at different rates while floating.
