RV.Net Open Roads Forum: Travel Trailers: water noise?
 > water noise?
lakelady4
West Central Minnesota
Posted: 05/06/12 04:28pm Link  |  Print  |  Notify Moderator
OK winter is done. spring is here, though it has been rain rain rain! We went to open the camper on our seasonal lot. NO mice, or evidence of mice! Yippee! Turned on the water...no leaks....which is great. Filled the flushable toilet ran the pink antifreeze thru everything. Thought everything was fine. Now when we turn the faucet on or the toilet tank fills or the shower is on..anything to do with water. There is a noise coming from somewhere, do not know where or from what. It only happens when the water is running...any ideas would be helpful.
Locky
West Michigan
Posted: 05/06/12 04:32pm Link  |  Print  |  Notify Moderator
Do you have a water hose hooked up to it or did you add water to your tank and using it that way?
greende
Syracuse,NY
Posted: 05/06/12 04:48pm Link  |  Print  |  Notify Moderator
Water Pump noise?
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
CavemanCharlie
Storden,MN
Posted: 05/06/12 07:01pm Link  |  Print  |  Notify Moderator
What kinda noise?
JJBIRISH
Butler, PA, USA
Posted: 05/06/12 07:37pm Link  |  Print  |  Notify Moderator
Without a better description and the fact that you are on a seasonal hook-up I would guess it is the Water inlet check valve noise…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
lakelady4
Posted: 05/06/12 09:08pm Link  |  Print  |  Notify Moderator
We do not use the tanks in the camper. The water comes directly from the hose which is connected to the camper. I do not know what kind of noise it is.
JJBIRISH
Butler, PA, USA
Posted: 05/06/12 09:22pm Link  |  Print  |  Notify Moderator
It is most likely the water inlets check valve chattering… it is where the hose is connected to…
If the noise is objectionable you can replace the inlet, but under the right conditions the new one might hum a little also…
HappyTrails2U2
Tennessee is home but being held hostage in GA.
Posted: 05/07/12 07:05am Link  |  Print  |  Notify Moderator
Look and see if someone has turned on the pump switch on your control panel which would kick on when you turn on the water.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
 > water noise?
