RV.Net Open Roads Forum: Pulling to one side when applying brakes
 > Pulling to one side when applying brakes
megsfolks
Spokane, WA
Posted: 05/06/12 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Any thoughts on why a steering wheel pulls rather sharply to the right when I apply my brakes?
Tire pressure is checked and equal on both sides. When driving down the road, the coach tracks straight and true.
I'm guessing that maybe the drivers side brake isn't engaging?
Mike, Lisa, and Megan
with Dill the Retriever
2007 Winnebago Journey 36G
2002 Jeep Wrangler
Roadmaster Sterling AT w/Brakebuddy Vantage Select
PressurePro all the way around
Progressive Industries EMS
2bzy2c
California
Posted: 05/06/12 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like unequal braking pressure. Yep, one of your front brakes is not doing its job.
My advice is worth exactly what you paid for it.
K Charles
Connecticut
Posted: 05/06/12 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yes front brakes
WI Bowhunter
Shiocton, WI
Posted: 05/06/12 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Would agree with all of the replies so far.
Keep the Shiny Side Up!
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
msmith1199
Central, CA
Posted: 05/06/12 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
My motorhome started doing the same thing. Shortly after it started, and before I took it in for service, I replaced all six tires. When they got the tires off the installer pointed out that a seal of some sort has blown on the left front wheel. Grease was all over and I suspect is getting into the brakes causing the left front brake not to work well which is why it's pulling to the right. This is just my theory as after I got the tires on I put the motorhome back in my shop because I haven't had time to take it to Frieghtliner yet. It needs a full service anyway so I'm going to take it in in the next week or two and get everything checked.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
Mody n Domy
Michigan
Posted: 05/06/12 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
When I took in my Workhorse for the break recall they told me that one of the front calipers never worked from the factory. After it was fixed it made a big difference in the breaking ability. They found it was the metering block (I think that's what they called it)not balancing the front breaking force. It had something to do with the anti lock breaks.
2008 Damon Challenger 378 on Workhorse chassis, 2008 HHR panel toad.
crasster
Dallas
Posted: 05/06/12 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a front brake issue. First you may want to start at bleeding the brakes, hopefully there is not any major problems.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
winpa4k
Altoona, PA
Posted: 05/06/12 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
When that happened with my 94 Brave I replace the front brake hoses and it fixed the problem.
msmith1199
Central, CA
Posted: 05/06/12 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think that's going to fix his problem. It's kind of hard to get all the air out of an air brake system.
garry1p
Oklahoma
Posted: 05/06/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
I had that problem once and the seal around the brake piston was bad allowing water into the piston area causing a sticking brake on that side.
A more common problem..Apply the brake and when the pedal is released one of the brake pads does not disengage causing a locked-up or dragging brake the RV will pull to the side that locks up.
This is caused by an internally collapsed brake line that you can't see. The brake line allows fluid to apply the brake and then will not let the fluid return or return slowly to the reservoir.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
