RV.Net Open Roads Forum: Pulling to one side when applying brakes
 > Pulling to one side when applying brakes
donsuefuggrwe
myrtle point ,or 97458
Posted: 05/06/12 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
It looks like you own a DP. Your problem sounds like a front wheel bearing oil wash gasket is leaking and spilling oil on the brake pads. Need a new gasket and brake pads. Not a big job.
DonBaja
Goodyear, Arizona
Posted: 05/06/12 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
This happens to my 36' DP occasionally and it always goes away, sometimes it shifts and pulls) to the other side. I think, on mine, it may be a dust issue and I blow the brake area out a little with compressed air. Take a look and if the problem isn't obvious "keep on truckin".
wolfe10
Posted: 05/06/12 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
My first thought. Air brakes rule out a lot of other causes.
Bottom line, you need to have the brakes checked by someone familiar with air brakes.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
mgh122
PA
Posted: 05/07/12 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Does your MH have automatic slack adjusters? Maybe it is sticking. Just another thing to check.
Mike & Peg
Aint' life grand!!
'05 Discovery 39S
'04 Grand Cherokee Freedom, M&G, Roadmaster Sterling
http://discovery-on-the-road.blogspot.com/
Zeus the Wonder Dog
"makes you wonder doesn't he"
fcooper
Richmond Hill, Georgia
Posted: 05/07/12 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
On my Freightliner chassis, the "S" cams that move the brake shoes needed lubrication. My right side front would not apply the brakes, therefore pulling to the left. If enough force was applied, the right brake would emit a loud "bang" and the right brake would apply.
The cure was removing the wheel, and applying a little high temp grease to the "S" cam and the associated rollers. It's a do it yourself job if you're careful. You don't have to lift that wheel, just ease it off when it's just a small height above the ground.
On mine, you loosen the lug nuts (an 8 ft breaker bar helps a lot), jack it up, remove the lug nuts , remove the wheel, slide the brake drum off the studs, and then you're looking at the S cam, shoes, and rollers.
To help get the wheel back on the studs, use a board or pry bar to help lift the wheel.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
B's Bunch
Shelbyville, TN. USA Why live any where else?
Posted: 05/07/12 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
x 2
Larry,Brenda,Travis,Jarred & MEME the Boston Terror TheBunch 2011 American Coach Revolution 42T
kg1d dx
Columbia Connecticut USA
Posted: 05/07/12 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
I had an axle seal leak and got oil on the brake shoes causing it to pull. Had the seal fixed and replaced the break shoes and problem solved.
2007 Sportscoach Elite QS40
msmith1199
Central, CA
Posted: 05/30/12 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
msmith1199 wrote:
My motorhome started doing the same thing. Shortly after it started, and before I took it in for service, I replaced all six tires. When they got the tires off the installer pointed out that a seal of some sort has blown on the left front wheel. Grease was all over and I suspect is getting into the brakes causing the left front brake not to work well which is why it's pulling to the right. This is just my theory as after I got the tires on I put the motorhome back in my shop because I haven't had time to take it to Frieghtliner yet. It needs a full service anyway so I'm going to take it in in the next week or two and get everything checked.
I took my rig in yesterday and got it back today. Problem was just as I assumed. Grease from the leaky seal got into the brakes. Cost to fix was $360. That included fixing the seal and replacing the brake pads. They tell me that once grease or oil soaks into the brake pad they have to be replaced so I had them do that too. On the drive back from the shop I noticed it would still pull a little to the right when braking, but I'm going to assume that's just because the brand new pads on the left need some breaking in.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
