Rick MC
Long Island
Hi everyone. Finally found a F350 2008 DRW. Pick it up tomorrow! I had added Firestone air bags to my F250, I loved how it leveled the load. Do I need to add airbags to the F350? I would really like some real world advice! My first trip out will be on Memorial Weekend, so I won't be able to see how it tows till then. Thanks in advance.
2008 F350 Lariat DRW 6.4 PSD Super Duty 4.10 Rear
2011 Komfort 3530 FBH
Q5 Curt 20K Slider
2008 F250 Lariat Super Duty Firestone Air Ride Bags {sold}
donn0128
Pronounced Ore-gun
No
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
n7bsn
Yes
Probably not
My 2008, F350 DRW has them, but I run them very light (10 lbs). I would not have installed them, they came with the truck
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
dbbls
Missouri
You might get a more useful answer if you told us the pin weight of your trailer. My pin weight is 2600 pounds and I do not have them. The truck drops about 3 inches. I suspect they would help me but I have been getting along without them.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
fj12ryder
Platte City, MO
It will probably depend on the actual payload of your truck. When I pulled our new toyhauler the pin weight put the truck down on the overload springs which made for a very rough ride. I installed the Firestone air bags and added about 50 psi. That got the truck off the overloads by an inch or so. The quality of the ride was tremendously improved. This is on a 2001 Dodge dually.
Howard and Peggy
"Don't Panic"
Artemus Gordon
Redding California
You know let's will tell you no. I put them on my F450 and frankly have come in handy. I keep them with about 15 PSI, but just last week needed to lift my trailer so auto jacks would retract. Bad slope and auto retract would not move. Added air and all was well. One more reason I like them!
2012 Montana 3750 Hickory Edition, 2013 Ford F450 Crew Cab 4x4 Platinum options
2012 3750 Montana
Generator Box
up2nogood
Utah
Did not like 3" drop on my SRW 1 ton ,added air bags, see how much it drops, if it is what you can live with, no you don't need them. A blanket NO is not the answer.
stickdog
29.820224, 81.94542
My pin is 3100 5er sits level.
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Chiefcpo
Huntsville, Alabama
Did not ever have air bags so I do not know. I installed super springs on our F350 sd drw 8' bed, 2011 and they help when on bad roads, 2012 3625re big sky rides well. and ride is ok when not loaded.
kab449
PA
You may not need them for the weight carrying ability but I feel they work to same way as an air pin. On a rough road they help to smooth out the front trailer bounce. Can't go wrong with them.
2011 F250 Lariat,SRW,Crew,6.7TD,ShortBox
2012 Montana 3750FL
Reese 18K Elite/Hidden Rails
