RV.Net Open Roads Forum: Truck Campers: New skin...
 > New skin...
oregonsteelheader
Oregon
Posted: 05/07/12 01:48am Link  |  Print  |  Notify Moderator
Currently in the middle of a tear down on my pop up TC..
I decided to ditch the corrugated fiberglass and opt for smooth sides...My question is should I go with smooth fiberglass or aluminum sheeting? I am leaning towards aluminum as I have access to a sheet metal shop, if aluminum what gauge would you think?
Also, any reason to put any type of vapor barrier material between the insulation/wood frame and skin?
Thanks,
OregonSteelheader
recycler
michigan
Posted: 05/07/12 06:39am Link  |  Print  |  Notify Moderator
not sure of the gauge it was.. I was looking at aluminium for mine was .032in i could only get it in 4x10 ft sheets.. unless you can get it wider sheets than that.. it may mean seems somewhere
1968 franklin 11fk
back to my 93 cummins
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/07/12 07:47am Link  |  Print  |  Notify Moderator
16ga (.064) will be much less prone to oil canning (wavy) than the thinner stuff. Also not likely to be punctured by a tree branch.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
d3500ram
colorado
Posted: 05/07/12 08:34am Link  |  Print  |  Notify Moderator
oregonsteelheader wrote:
...Also, any reason to put any type of vapor barrier material between the insulation/wood frame and skin?...
Generally , any type of VB would preferably be located on the warm side of the insulation (i.e. on the inside) to prevent batt insulation from absorbing moisture from the inside... not sure what you have in the camper... but you perhaps might consider a housewrap like Tyvek??? ...it is "breath-able" yet provides waterproofing features.
* This post was edited 05/08/12 01:28am by d3500ram *
oregonsteelheader
Oregon
Posted: 05/07/12 11:49pm Link  |  Print  |  Notify Moderator
Thanks guys. I went with .050, will pick up the material tomorrow. Got the TyVek done tonight.
d3500ram
colorado
Posted: 05/07/12 11:58pm Link  |  Print  |  Notify Moderator
You may want to insure that the Tyvek is appropriately spaced from any heat sources such as the furnace exhaust or any other possible heat sources... I do not know if it is a concern...you may be fine, but a little extra clearance for assurance is not a bad thing. I tend to try and "look ahead" and err a little extra on safety's side.
ON EDIT: I had not looked on the Tyveck website in a while... out of curiosity I looked and found this: DuPont™ Tyvek® is combustible and should be protected from a flame and other high heat sources. If the temperature of DuPont™ Tyvek® reaches 750°F (400°C)
* This post was edited 05/08/12 01:30am by d3500ram *
 > New skin...
