RV.Net Open Roads Forum: Best way to connect #6 wire to a #8 Screw Terminal?
 > Best way to connect #6 wire to a #8 Screw Terminal?
cruz-in
Southern Maryland
Posted: 05/07/12 06:53am Link  |  Print  |  Notify Moderator
Hi All,
My solar charge controller has fairly small terminals (like #8 screws). I can only find appropiate sized crimp on connectors for up to #10 wire. Any thoughts on how to either use a #6 wire with a #8 screw terminal or to reduce my long #6 run to #10 for connection to the terminals?
Thanks
1995brave
San Antonio, TX
Posted: 05/07/12 07:00am Link  |  Print  |  Notify Moderator
Will any of these fit?
harold1946
Surprise Arizona
Posted: 05/07/12 07:37am Link  |  Print  |  Notify Moderator
Acording to the link provided the terminals will accept #6 wire.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
cruz-in
Southern Maryland
Posted: 05/07/12 07:15am Link  |  Print  |  Notify Moderator
Yep however they only go up to #10 wire. The way the terminals are configured, a #8 spade connector is preferred
Oh by the way it is a Sunsaver MPPT 15 controller. FYI here is the link with pict:
Sunsaver MPPT Datasheet
cruz-in
Southern Maryland
Posted: 05/07/12 07:51am Link  |  Print  |  Notify Moderator
Yes, I have chatted with Morningstar Tech Support about this. They acknowledged they know of no lug that will allow the attachment of anything bigger then #10 wire. They suggested (if using larger wire than #10) strip the wire, split the conductor in two, place half on each side of the terminal and tighten the terminal. I would rather use a lug as I think it is cleaner. Hence my question.
1995brave
San Antonio, TX
Posted: 05/07/12 08:40am Link  |  Print  |  Notify Moderator
How about one of these ?
smkettner
Posted: 05/07/12 09:28am Link  |  Print  |  Notify Moderator
Closest I know is a lug for #6 wire #10 screw
Probably need to narrow the lug end to fit.
Otherwise use some of their #6 butt splice connectors to step down to #10. Fold the #10 over to get a better crimp.
675 watts solar
cruz-in
Southern Maryland
Posted: 05/07/12 09:56am Link  |  Print  |  Notify Moderator
1995brave and smkettner,
Thanks for the links one of those might work. certainly closer than anything I have been able to find...
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 05/07/12 12:21pm Link  |  Print  |  Notify Moderator
With a pair of good diagonal cutters, cut a slot in the tip of the lug to the #10 hole. Carefully squeeze the tips together as best as possible. Use a tiny file to customize the slot. Grind off or file the edges on the outside of your new "fork" terminal to fit into the slot of the controller. I grumble every time I have to do this. I have a bin of around 200 6AWG/#6 fork (spade) milspec terminals, but we have a small problem with logistics or I'd mail you some.
cruz-in
Southern Maryland
Posted: 05/07/12 12:26pm Link  |  Print  |  Notify Moderator
mexbungalows,
thanks that is the approach I will take...
Appreciate the thought on mailing a few...darn logistics...LOL...
should be pretty easy to cut, squeeze, and file.
