Larry Sanders
Sarasota, Florida
Just a reminder to check tire pressure before every trip.
Friday morning I checked my pressure and the right inner Dually was down
to 20lbs. I inflated and waited a few minutes and tire was loosing air.
Brought to my tire shop and found that the valve stem was loose.
Going to purchase a valve stem tool this week. Scary part is I just purchased the Rig last week and dove 800 miles.
Larry & Jamie Sanders
2008 Born Free
27 RSB
motorcycle jack
FT all over
A tire pressure monitoring system is your BEST friend. It will save your butt and possibly your rig. Failing that - yes check all tires every morning before you leave. Having put over 15,000 on this year, moving from CG to CG on the average every 5 days, it is amazing how many I see just get up, connect up and go.
John
"Motorcycle Jack"
Life time Good Sam Member
Blog: My RV
5th Wheel Blog
Full timing isn't "always camping". It's a different life style living in an RV.
RCMAN46
NorthWest
Get a TPMS system. Very easy and safe to check tire pressure every morning and the most important reading is after about 10 miles of driving. If I have my tire pressures right I find they will all be the same regardless of the weather conditions. The tires on the sunny side are no longer affected as the heat generated from driving and cooling from passing air is the major factor.
Also each time you check a tire with a tire gauge you risk a Schrader valve not seating and giving you a slow leak that may not be noticed until the tire fails 100 or so miles down the road from loss of air.
hershey
Albuquerque,(fulltime) NM, USA
I actually check my tires regularly with a gauge, but I thump the tires with my tire billy at every stop along the way.
I know the tire thump isn't accepted by the pros as an accurate means of pressure testing but if a tire is several pounds lower than the rest, you can detect a difference in the sound.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
peaches&cream
Northwest Georgia
hershey wrote: I actually check my tires regularly with a gauge, but I thump the tires with my tire billy at every stop along the way.
Everyone to what fits their needs, but, I check pressure and thump my tires every 8 seconds with my TPMS. I also keep up with the individual temps of each tire, including my toad.
2005 Holiday Rambler Ambassdor, 36PRT, 330 Cummings
Toad 1995 Miata
Gale Hawkins
Murray, KY
peaches&cream wrote: hershey wrote: I actually check my tires regularly with a gauge, but I thump the tires with my tire billy at every stop along the way.
WM will help you pay for at TPMS by letting you overnight for free while you save money for a TPMS.
I had rather leave home without the cell phone as no TPMS.
skipnchar
Topeka or somewhere else
I think once per trip isn't NEARLY often enough. I check air pressure before each days travel.
Larry Sanders
Sarasota, Florida
I think that I'll take the advice and get a TPMS System installed.
Thanks
az99
Pa.
For you guys with the TPMS. How many times have you actually had a tire go down that the TPMS detected, that you would not have, by checking pressure on a regular basis ?
Brent and Gina
Arkansas
TPMS...Gale, seriously? Slipping in a dang WM comment?? LOL
