RV.Net Open Roads Forum: Class A Motorhomes: Diesel vacuum pump
 > Diesel vacuum pump
rooster
somewhere in the Ocooch
Posted: 05/07/12 07:08am Link  |  Print  |  Notify Moderator
Has anyone had any problems with their vacuum pump? I had some work done on the alternator & A/C system, & now the vacuum pump dosen't work. I don't know if they are related as the coach is a pusher,(freightliner/cat) & the vacuum pump is up front on the firewall. So I have no control over cabin venting. Any ideas?
Tony & Cam
1999 Tradewinds 7371
2001 Cherokee
Mike Hohnstein
Germantown, Wi
Posted: 05/07/12 07:29am Link  |  Print  |  Notify Moderator
Obviously you should return to the place that did the work related to loss of vacuum pump function. Could be rubber hose disconnected or knocked loose.
rgatijnet1
Posted: 05/07/12 07:36am Link  |  Print  |  Notify Moderator
If it is an older coach, hoses deteriorate and sometimes just moving one during other work will cause it to crack/leak. I would guess that IF the vacuum pump is running, and creating vacuum, you should hear a leak hissing.
wolfe10
Posted: 05/07/12 07:39am Link  |  Print  |  Notify Moderator
Find the pump-- probable locations are in the bay forward of the driver's front tire or in the very nose. No rocket science-- it runs on 12 VDC. The pressure switch may be internal or external, depending on which pump you have.
Could be a vacuum line that came off or is cracked (removing the vacuum line from the pump and sucking on it should hold a vacuum). Could be a blown fuse (no 12 VDC-- replace fuse). Could be a bad pressure switch or pump.
Once you fine it, troubleshooting is pretty easy.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
rooster
Posted: 05/07/12 07:47am Link  |  Print  |  Notify Moderator
thanks for the replys. I know where the pump is, as I said, it's on the firewall in front. It just dosen't run. I looked for a fuse in line & in the fuse block, but it must be on a circuit with other things & everything else seems to work??
The coach is a National Tradewinds if that helps.
wolfe10
Posted: 05/07/12 08:01am Link  |  Print  |  Notify Moderator
Do you have 12 VDC to the pump?
Locate your fuse block for other items that only run with the engine/ignition on. That is its more likely location.
jimrose
Hoffman Estates, IL
Posted: 05/07/12 08:23am Link  |  Print  |  Notify Moderator
We had the pump go bad on our Holiday Rambler. Purchased a replacement from our local Ford Dealer.
Jim
01 38' Holiday Rambler Endeavor DP Cummins 330 HP ISC
04 Ford Explorer MG Brake System Wireless Lights
