cpope84
Marshfield, MO
I have a 2012 xlr 35x12 and have been camping in it for about 6 weeks now. I have had the electric water heater turned on and has been working fine. All of a sudden it has only been making lukewarm water. Any ideas what the problem could be? Thanks
2012 Ram 3500 DRW Longhorn
2012 XLR Thunderbolt 35x12
donn0128
Pronounced Ore-gun
Electric element has shorted out. Switch to gas and report back.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Fishinghat
Western Washington, USA
Lukewarm? If the electric element had failed, your water would be the same temperature as the cold water. You may have inadvertently opened the winterizing valve which mixes cold with the hot water.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
cpope84
Marshfield, MO
That was as of last night. It felt a little cooler this morning as maybe if it was cooling off. I haven't messed with the valves any. I'll mess with it as soon as I get back to the rig later today.
cpope84
Marshfield, MO
GFI plug was tripped in the bathroom. Didn't think the electric water heater would be hooked into it but easy fix.
cpope84
Marshfield, MO
Well it worked for a day and the water was hot and now it's not working again. Gfi plus isn't tripped this time and all breakers and fuses are good. Any suggestions now?
wborst
North Carolina
Does the water heater operate on gas? If it does, you probably have a bad electric element. It probably caused the GFCI to trip when it was failing. then it finally opened up altogether.
If it will not operate on gas or electric, disconnect and reconnect the control board connector a few times to clean the contacts. This may help.
Brenda, Bill and our little dog Madison
2007 Pilgram Legends 31RE3SLF-5
2005 Dodge 2500 Quad Cab 4x4 w/Cummins Turbo Diesel
cpope84
Marshfield, MO
It works on gas. I guess the element has burnt up already. I've only used it for about 6 weeks.
wborst
North Carolina
You need to be certain that the tank is filled with water before you turn on the electric element. Turning it on with the tank empty will burn it out in minutes.
