RV.Net Open Roads Forum: Travel Trailers: Painting TT wheels, tips?
 > Painting TT wheels, tips?
jeeptp75
Johnstown, PA
Posted: 05/07/12 07:51am Link  |  Print  |  Notify Moderator
My TT is going on 8 years old now and still looks in great shape with the exception of the wheels. The center caps are platic and look terriable, not sure what I can do there but I figured I could paint the wheels to give them a refreshed look. Any suggestions on what I need to do to prep them and what type of paint I should use and so on?
Thank You,
Tim
2012 Ford F-150 V8 5.0
2014 Cougar X-Lite 28RBS
swebber
Brunswick , MD
Posted: 05/07/12 07:56am Link  |  Print  |  Notify Moderator
I just painted the wheels on my enclosed utility trailer. As most painted items, removing any oil or grease from the surface is required. For this I used mineral spirits. After scuffing the surface, I wiped the wheel down once again using mineral spirits. Let this dry completely before painting. I used the "Hammered" surface paint from Rust-O-Leum. Apply light coats until you get the coverage you want. Let dry thoroughly before handlilng the wheel.
Good luck !!
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
weathershak
Not sure, I need to look out the window
Posted: 05/07/12 08:11am Link  |  Print  |  Notify Moderator
Looks Nice !!!!!! Even from here.
Full timing it since July 2012 My pics
fla-gypsy
North Florida
Posted: 05/07/12 11:05am Link  |  Print  |  Notify Moderator
Good luck !!
Do you have any pics of the work? I want to do this also.
Chrisatthebeach
The beautiful low country of South Carolina
Posted: 05/07/12 01:17pm Link  |  Print  |  Notify Moderator
Just before I replaced my tires 2 years ago, I took them off one at a time, sanded them and laid flat on the ground and brushed on multiple coats of oil based Rustoleum white paint. I was planning to replace the tires so I did not have to worry about getting any on the stems or the old tires. While off mine has chrome center caps, they had some rust spots but Turtle Wax chrome polish took care of that. You have to look close to see any brush marks and at around 5 dollars for paint, sandpaper and some foam brushes it beat the cost of new wheels.
Chris & Dianne plus two boys, both of them are Eagle Scouts.
Jayco Designer 3110
F250 PSD 4x4 Crew Cab
Francesca Knowles
Port Hadlock, Washington
Posted: 05/07/12 01:41pm Link  |  Print  |  Notify Moderator
One thing I've learned is that even when the paint looks "dry" it's still very fragile until it's fully cured, which takes about a week in most circumstances. (The pros use "ovens" to hasten this process).
If you can wait that week before using/exposing the wheels to roadgravel, etc. they'll be much less susceptible to chips in the paint. Better yet is to keep them off the rig until fully cured- lugnuts installed over uncured paint will lift it off the first time they're removed.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
6.7 tow rig
kentucky
Posted: 05/07/12 01:48pm Link  |  Print  |  Notify Moderator
I recently painted the rims that are on my old Jeep CJ7. I used paint stripper to remove the original paint. It took them down to bare metal with very very minimal effort. You just brush it on let it sit and the paint bubbles up and you peel it off.
After that I cleaned them to make sure there ws no more stripper on them, lightly sanded them, and painted them with Ace Hardware version of Rustoleum Stops Rust. That was a year ago and they still look great even after a couple off road trips. Like mentioned earlier the longer you can wait after painted the better off you will be. Super easy to touch up as well.
2012 Dodge Ram 2500 Cummins 4x4 3.73 rear end
2013 Primetime Lacrosse 318bhs
82corvette
Southeast Nebraska
Posted: 05/07/12 08:00pm Link  |  Print  |  Notify Moderator
When I painted my wheels I went ahead & scuffed the plastic center caps and painted them also. I am now going to scuff the stove vent & door window frames and cover that yellow with some gloss white.
smkettner
Posted: 05/07/12 08:05pm Link  |  Print  |  Notify Moderator
Get new caps and spray away. Although last time I did this I sent them to a place that did powder coating.
675 watts solar
swebber
Brunswick , MD
Posted: 05/09/12 05:55am Link  |  Print  |  Notify Moderator
I will get a few pics tonite for you !
