RV.Net Open Roads Forum: Class A Motorhomes: Winterize Question
 > Winterize Question
ROYBUCK
Newport NC
Posted: 05/07/12 07:57am Link  |  Print  |  Notify Moderator
I know this is not the time to some of you for this question. I always do nothing but blow my lines out and pour antifreeze down the traps and a bulb in the wet bay. This past winter I deceided I would put the antifreeze in the lines, I could not get the pump to pull the antifreeze out of the jug, now before I did this I blowed out the lines, could me blowing out the lines put air in the line and prevented the pump from pulling the antifreeze out of the jug. Now I know the procdure to do this by pass water heater and all. Thanks Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
2002 Endeavor 330 ISC 3 Slides
wny_pat
Western NYS
Posted: 05/07/12 07:58am Link  |  Print  |  Notify Moderator
Your pump should have self primed. Were you on the suction side of pump?
2inAlabama
Huntsville, AL
Posted: 05/07/12 08:43am Link  |  Print  |  Notify Moderator
Air in the lines should not affect the pump pulling the antifreeze from the jug. Has the pump worked pulling the water from the tank?
Just DH & DW
JTHarley
Northeast, Michigan, USA
Posted: 05/07/12 09:05am Link  |  Print  |  Notify Moderator
You do it just like I do and the pump has always sucked up the pink stuff. This year I put the jug on a bucket turned upside down and it did pull it in a whole lot faster than last year because it was above the pump.
Jim , MJ & Spirit of Sambuca Bear
"He's one big Newfie"
Dynamax Ultra 450UL
450 MBE
Jeep Sahara Toad
