RV.Net Open Roads Forum: Class A Motorhomes: Diesel loss of power
 > Diesel loss of power
Executive
Posted: 05/14/12 12:56am Link  |  Print  |  Notify Moderator
ANOTHER post where the OP gets lots of responses, but is never heard from again....sometimes I wonder why we bother.........rant over....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
klm
SIOUX FALLS, SD
Posted: 05/14/12 05:24am Link  |  Print  |  Notify Moderator
I have a cummins 5.9 - had a similar problem on the hills. Unfortunately, for me, it was my bosch 44 fuel pump - it was an expensive fix - about $1200 - but no issues since. Like the OP, I had the fuel filters changed - a couple of times, to no avail.
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
Sandra
Lake Arrowhead, Ca.
Posted: 05/14/12 09:18am Link  |  Print  |  Notify Moderator
Maybe it's because we are still trying all the suggestions. That's what we are doing. As soon as we cure the problelm will let you know. Thanks for all the help.
Sandra
Lake Arrowhead, Ca.
Posted: 05/17/12 10:47pm Link  |  Print  |  Notify Moderator
Thanks for all the suggestions. Turns out it was the exhaust brake that was broken and stayed in the closed position. When it was wired open ran good. Replacement has been ordered,waiting for install.
wolfe10
Posted: 05/18/12 06:42am Link  |  Print  |  Notify Moderator
Sandra,
What exhaust brake did you have/did you order?
And when was it last lubed (if PacBrake)?
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
Sandra
Lake Arrowhead, Ca.
Posted: 05/18/12 07:36am Link  |  Print  |  Notify Moderator
Not sure on either counts. It is a 10 year old Cummins engine. Have not picked up the unit or seen a bill.
Busskipper
Arnold,Md
Posted: 05/18/12 08:33am Link  |  Print  |  Notify Moderator
Executive wrote:
Since you just had the filters changed, I would start there first. Make sure they were filled and tightened properly. If they check out ok, examine the lift pump....Dennis
On edit: What is your turbo boost showing....
Had a similar issue a few weeks ago and it turned out to be the turbo was not tightened when they worked on the exhaust leak -- tightened it up and ran like a champ.
BOL,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
MDX-FMCA--M&G Brake
States traveled in this Coach
Executive
Posted: 05/21/12 10:07am Link  |  Print  |  Notify Moderator
Sandra, thanks for sharing what was wrong with your coach. While the exhaust brake is expensive, it's easy to replace. Consider upgrading to the PXRB, you'll be glad you did...not much extra but the benefit is great. I had a Dynasty with a 8.3 Cummins and it made a world of difference. I replaced mine myself in a campground in about 45 minutes so replacement is not a big deal. You're maybe looking at an hour or two diagnosis charge plus install labor...good luck and I'm glad it was something simple....the turbos are expensive....Dennis
