bob213
Fresno, CA
TST has a new flow thru monitor for their TPMS. They also have an internal sensor with a seven year battery. Which would be the best way to go? On a 14" rim would you need the 2" or 3" valve stem internal mount? Suggestions...opinions?
MyakkaTT
Bradenton, Florida
I have had the older 510 TST for about 5 years, the batteries just died in the sensors so TST offered me a good deal on the new FLow Thru and the 507 monitor. Hopefully they are reliable as the old system. Great Customer Service as well.
2007 McKenzie Starwood SL 31 BHD
2006 Dodge Ram 2500, Quad Cab, 4x4, CTD
My Wife: Dawn
Myself: Scott
Our Dog: Our new Fur Kid, Kylee
Our Photos
Trailer Mods
"Quietly Making Noise"
RVUSA
Orlando, FL, USA
What ever one that comes with a temp sensor seems like the only way to go to me. By the time the tire loses pressure in a blowout, it's too late. It builds heat early enough that you might catch it be fore it's too late.
bob213
Fresno, CA
I agree but....all three have temp. sensor.
Jack&Kay
Santa Rosa, Ca
I wish I had the flow-through model. I don't like having to take them off to air them up. that being said, I don't have to air them up that often, the monitor tells me the pressure.
Jack
Jack & Kay
2007 Tiffin Allegro 28DA
Ford Chassis V-10
Blue Ox Tow Bar to a 94 Honda Accord
FMCA #F341229
powderman426
ohio
The next time I have need to remove a tire, I plan on putting a hole 180 degrees from current valve stem so I can add a second valve stem to make air adjustments without having to remove the sensor.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
LTCLarry
Maggie Valley, NC
Folks, I am missing something so please educate me. It seems some of you are saying you can't add air without taking off some sort of sensor. The sensors for my Silverado are inside the rim. Are there no after market systems for TT's that function that way.
Ron3rd
Upland, CA USA
Larry,
They're talking about an external TPMS system that is commonly run on trailers, etc. The sensors screw on to the valve stem and you have to remove them to add air. The sensors transmit to a monitor in the cockpit.
BTW, there are internal systems too, similar to your Silverado, but they're not as common as the external.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
bob213
Fresno, CA
Don't know about other systems but TST just introduced their "internal" mount sensors. That's the question...is that the one to go with? Doubt if anyone has them so I'm looking for opinions...
HSIKES
Wilmington,NC
I just installed the internal sensors from TST 507 on my Fleetwood Providence. Used the 3" sensors on the steer front tires and the inside dually tires. I used the 1" sensors on the outside duals.
I have Alcola Aluminum wheels (4) with steel wheels (2) on the inner duals.
I also have 4 screw on sensors that are transfered from vehicle (Buick Enclave) to vehicle (golf cart dolly with Honda CRV. Takes a couple of minutes to remove and install.
Everything works great and there are major improvements since the first problematic unit I bought several years ago. Customer service was great in deciding on the unit and the sensors
Horace & Bobbi
DRAKE - Yellow Lab (rescue dog)
2005 Fleetwood Providence 39 L; 4 slides; 350 Cat
2000 Saturn LW TOAD
2009 Buick Enclave CLX 2
Preach the gospel at all times. And if necessary.....use words.
