RV.Net Open Roads Forum: Tech Issues: RV Door 90 degree attachment
 > RV Door 90 degree attachment
Bounder Lew
fulltimer Melaque Mex , site 33 Oceanside
Posted: 05/07/12 12:34pm Link  |  Print  |  Notify Moderator
I have seen a short Fleetwood A Class that had a special arm at top of door to keep it at 90 degrees open instead of totally open against the wall of RV. Where would I find such an attachment.
A lot in Melaque Mexico in winter and Victoria BC in summer - 2000 Fleetwood Bounder 31 W
V10
03 Tracker ZR2 Towed
Excalibar Towbar and SMI Stay in Play braking
zigzagrv
Nazareth, PA
Posted: 05/07/12 01:08pm Link  |  Print  |  Notify Moderator
You should be able to find a pneumatic door piston at any home center. They also prevent the door from slamming shut when you close it.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
'95 Tracker toad
Bounder Lew
Posted: 05/07/12 02:53pm Link  |  Print  |  Notify Moderator
The pneumatic screen door cylinders are designed for doors about 3 inches apart. the RV screen door is abutted to the door when closed!!
SWKansas4
Southwest Kansas
Posted: 05/07/12 03:04pm Link  |  Print  |  Notify Moderator
Our new Puma has to have a 90 degree hold back due to awning location. I picked up couple of spares pretty easily at our semi-local RV dealership.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 05/07/12 04:22pm Link  |  Print  |  Notify Moderator
I was told to use caution with these devices. Every time you pull the door to shut it or open it you are introducing flex to something that you really want to remain straight. For sure you want to use the lightest one that will do the job for you and not anything bigger. Some doors are built stronger than others.
Could you use a second "Swing-a-Way" handle with a door stop feature up nearer to the door knob puller to hold it open?
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
mnoeltne
Grantsville, UT
Posted: 05/07/12 04:44pm Link  |  Print  |  Notify Moderator
I've got a 2005 Fleetwood Fiesta 26Y that has such an arm. It's actually a gas strut similar to those used on a hatchback car. There is a right angle metal bracket with a ball stud mounted on the wall of the RV, and another bracket with a ball mount attached to the door. I don't have details on the strut itself, but I will have that info next weekend as the gas strut just failed this weekend. It was 7 years old, so I don't feel too bad about the failure.
I will post back to this thread next weekend when I have the make and model info off the strut. I'll also try to get some pics of the mounting brackets. Looks like it would be easy to construct.
Mark & Joyce Noeltner along with Chico & Cricket the Chihuahuas
2001 Jeep Cherokee Sport
Bounder Lew
Posted: 05/07/12 04:54pm Link  |  Print  |  Notify Moderator
Mark Your RV was the model I saw I think. Thanks in advance for information on where I might be able to buy the complete set up.
I am annoyed at the fact that the door covers a compartment I use a lot and having to alite the RV to close unlatch the door to close it!!
jetboater454
Camping or home
Posted: 05/08/12 04:34am Link  |  Print  |  Notify Moderator
Here is a pic of mine. Just a gas strut.
And opened.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
kirbybear
Ft. Lauderdale Fl USA
Posted: 05/08/12 07:31am Link  |  Print  |  Notify Moderator
I just replaced mine at O'Reillys auto store. Since they only go by car model I had to search the supply for one that physically matched. The struts are extended so the pin to pin attachment length measurement is required. About $26.
OldGreaser
South Texas
Posted: 05/08/12 08:00am Link  |  Print  |  Notify Moderator
Readily available at RV stores. We got ours installed at a very small independent operation. They had a bin of them in various sizes. Been running them (2 man doors) for a year with no problem except one did get stressed by a visitor. I had to add screw anchors and it's been good since.
