RV.Net Open Roads Forum: Travel Trailers: holding tank insulation
 > holding tank insulation
chopper5670
kentucky
Posted: 05/07/12 12:40pm Link  |  Print  |  Notify Moderator
my holding tanks are not heated or insulated . i would like to do both ..any suggestions?
pianotuna
Regina, SK, Canada
Posted: 05/07/12 12:47pm Link  |  Print  |  Notify Moderator
Hi,
If you enclose them consider a duct from the furnace for warming them.
If not then there are "stick on" tank heaters available.
Mine were enclosed and supposedly heated--but I found I needed to add a small heater that is thermostatically controlled. I did add a 120 volt outlet in the enclosure which I power from my inverter and/or shore power.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
chopper5670
kentucky
Posted: 05/07/12 03:38pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,thank you
chopper5670
kentucky
Posted: 05/07/12 03:39pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
thank you for your help
rgolding
Southern Illinois
Posted: 05/07/12 04:53pm Link  |  Print  |  Notify Moderator
Ultrheat AM-Model 0900
or
carry a gallon of RV anti-freeze and dump some in for the times it is needed.
Is this an ongoing constant need of being below freezing?
boosTT
Milwaukee
Posted: 05/07/12 05:15pm Link  |  Print  |  Notify Moderator
I would just pour a bunch of antifreeze in.
smkettner
Posted: 05/07/12 06:30pm Link  |  Print  |  Notify Moderator
I installed Ultra Heat brand tank heaters. I went with 120v heaters as if it is that cold I plan to be plugged in. The fresh water tank I did the combination 12v/120v for additional heat and heat while in transit. Add up the 12v amps before you buy a bunch and need to add a second converter. You can find lower cost stuff on ebay but watch the wattage as you may need two pads for larger tanks. My tanks have been good down to about -5F in my fair weather trailer.
I used 120v heat tape to wrap the waste pipes and covered that with self stick foam insulation from Home Depot.
My trailer underbelly is fully exposed.
www.ultraheat.com
675 watts solar
skipnchar
Topeka or somewhere else
Posted: 05/07/12 06:59pm Link  |  Print  |  Notify Moderator
Electric is the way to go if you TRAVEL in cold weather. Usually there are 120 volt AC heaters for when camping and 12 volt heaters for when towing.
Good luck / Skip
