RV.Net Open Roads Forum: Tech Issues: Hidden plumbing?
 > Hidden plumbing?
ExTexan70
Greensboro, NC
Posted: 05/07/12 01:13pm Link  |  Print  |  Notify Moderator
Okay, so I now have a 2002 Coachmen Catalina 25BQS trailer, and upgrade in size and room over my old hybrid. I love it, and probably more importantly, so does my wife!
I do have a minor issue. I flushed the fresh water system with bleach. In the course of doing so, I pretty much filled the fresh water tank. I wanted to drain it, so I found the drain pipe below the RV. I took the plug out of it, and nothing happened. No water draining out, nothing.
Does anybody know if there is a drain shutoff valve for this thing, and, if so, where the heck is it? The tank and pump are apparently beneath the slideout, and I be d---ed if I can figure out how to get at them! Surely you don't have to disassemble the slideout to access these parts?
Any help would be greatly appreciated!
sgip2000
Oregon
Posted: 05/07/12 01:17pm Link  |  Print  |  Notify Moderator
Try opening the fill cap. There could be a vacuum keeping the water from coming out.
J Walker
Oakton, Va
Posted: 05/08/12 07:28am Link  |  Print  |  Notify Moderator
In any case empty the fresh water tank with the bleach using the water pump if necessary. Bleach can harm pipes if the concentration is too high. I use city water which always has chlorine in it for sanitizing. I don't have any problems doing that.
Jim Walker
2000 34' Damon Ultrasport DP
2009 Malibu
Brake Buddy
 > Hidden plumbing?
