RV.Net Open Roads Forum: Class A Motorhomes: Analysis of battery/charging times using generator...
 > Analysis of battery/charging times using generator...
nancyjerry
on the road
Posted: 05/07/12 03:03pm Link  |  Print  |  Notify Moderator
hi,
we are going into the woods for 4 months - no hook ups,no solar. Have Monaco Dynasty 2001,40' DP with 3 stage charger and Onan Generator.
We need new house batteries. Does spending alot of $ on a more expensve set that charges quicker, really save us on how much diesel it takes to charge using diesel at $4.25 gal?
Make sense?
Thank you,Nancy
2oldman
Winchester WA
Posted: 05/07/12 03:06pm Link  |  Print  |  Notify Moderator
What kind of batteries 'charge quicker'?
harold1946
Surprise Arizona
Posted: 05/07/12 04:06pm Link  |  Print  |  Notify Moderator
AGMs will accept a much higher charge rate and will "charge quicker". They are also the most expensive to purchase.
If recharge time is the only thing being considered I would say no they would not be worth the investment.
Running the genny for charging only for 3-1/2 hrs. only amounts to about 1-3/4 gallons of fuel.
* This post was edited 05/07/12 04:22pm by harold1946 *
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
driveby
Vancouver BC Canada
Posted: 05/07/12 04:17pm Link  |  Print  |  Notify Moderator
genny use is generally considered to consume between .5 and 1 gallon per hour. or $2.12 to $4.25 per hour money wise using the OP rates.
at best one might save an hour and to be generous 2 hours per day of genny use that would be 2.12x120 days = $254.40 in fuel use or best case save $508.80. Could be worth your time. Get some quotes on batteries (however many you'd need 2-4 I assume) and see the difference in price between Lead Acid and AGM.
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
pianotuna
Regina, SK, Canada
Posted: 05/07/12 04:20pm Link  |  Print  |  Notify Moderator
Hi,
If the batteries will last "overnight" I'd be quite tempted to use them for this four month trip.
Why? Because unless a battery is fully charged to 100% at least once every 5 to 7 days the lifespan may be shortened. It may take 24 hours of run time to fully charge a battery bank. At 1/2 gallon per hour that's quite a bit of money--$48 bucks more or less.
So buy the new batteries *after* your trip--and then you won't have to do the $48 generator run once a week. Four months of 50% to 90% with one day of 50% to 100% will "eat" about 1/4 of the new battery banks cycle life.
If the old battery bank is truly "done in" get a couple of reconditioned batteries and abuse them to your hearts content.
Or, add sufficient solar to meet your daily energy demands and put the saved costs of running the generator into your pocket.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Ivylog
Blairsville, Ga. USA
Posted: 05/07/12 04:56pm Link  |  Print  |  Notify Moderator
My 2000Watt inverter/charger will only charge 60amps max (not the rated 100) and I have 800 amp hours of AGMs. I'd buy another charger and split your battery bank.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
skipnchar
Topeka or somewhere else
Posted: 05/07/12 06:42pm Link  |  Print  |  Notify Moderator
Faster charging means less power. Probably the OPPOSITE way you'd want to go for what you're wanting to do.
smkettner
Posted: 05/07/12 08:00pm Link  |  Print  |  Notify Moderator
Assuming the OP has the same I would be looking at why it is programed for only 60 amps. I assume 4 to 8 batteries and should easily be able to go 100a if the wire is good.
I would skip the AGM unless money is easy. If so I recommend Lifeline.
Best value is something like Costco or Sam's club 6v GC2 wired in pairs.
675 watts solar
MNtundraRet
Bloomington, MN
Posted: 05/08/12 05:53am Link  |  Print  |  Notify Moderator
nancyjerry wrote:
hi,
Make sense?
Thank you,Nancy
problem posting this morning! Message did not post.
* This post was edited 05/08/12 06:24am by MNtundraRet *
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
Doug and Cassi Glass
Clifton Forge, VA
Posted: 05/08/12 06:03am Link  |  Print  |  Notify Moderator
A little Honda or Yamaha 2000 watt gen inverter will cut your fuel use down to about a gal of gasoline every five hours.
There is NO way I would head out for four months knowing I had bad batteries.
