RV.Net Open Roads Forum: Class A Motorhomes: Analysis of battery/charging times using generator...
 > Analysis of battery/charging times using generator...
bluwtr49
Green Valley, AZ
Posted: 05/08/12 07:31am Link  |  Print  |  Notify Moderator
Our 100 W solar panel works well keeping the batteries topped of during the day. A friend that has four 100 w panels can go a week without genny running. Just a tought.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
BigRabbitMan
Dixon, CA
Posted: 05/08/12 09:41pm Link  |  Print  |  Notify Moderator
Doug and Cassi Glass wrote:
There is NO way I would head out for four months knowing I had bad batteries.
I concur with this opinion. Also, the biggest effect on your genny run time is not the batteries, but how you use electricity.
If you are conservative and turn off lights not needed, etc verses leaving things turned on while not in use, will reduce you genny use more that anything else.
Sounds like a great trip to me!
BigRabbitMan & DiamondGal
Diatomaceous Earth for health
76 FMC #1046, Gas Pusher W/Chrysler 440-I
"You're never too old to learn something stupid."
DataStorm Satellite internet / I am here-click to see
nancyjerry
on the road
Posted: 05/09/12 10:59am Link  |  Print  |  Notify Moderator
Would NOT even consider going without good batteries, that is why we are researching now. Put us in the 'common sense' section!
DH analyzes almost everything.... Hence the question. He is sold on a set, just not the $400 a piece ones..
Thanks for all the input!
Nancy
mena661
Posted: 05/09/12 05:18pm Link  |  Print  |  Notify Moderator
I'd rather spend less money on more battery capacity so you won't have to recharge as often. I was in the market for AGM batteries myself (four Universal 4D's @$370 each). I ended up going with 6V flooded batteries for $100 each less than those that had more capacity.
Trojan L16 6V's 740 Amp-hours
