RV.Net Open Roads Forum: Forum Technical Support: new topic posting test
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > new topic posting test
IAMICHABOD
Sunny So Cal
Posted: 05/07/12 03:18pm Link  |  Print  |  Notify Moderator
I have tried 3 times today to post a new topic and as it was loading it stopped and said web site not foundww.rv.net but I can access and reply to posts??
2006 TIOGA 26Q CHEVY 6.0 VORTEC
Recycled El Monte RV Rental
Buying A Rental Class C
IAMICHABOD
Sunny So Cal
Posted: 05/07/12 03:19pm Link  |  Print  |  Notify Moderator
I see that this one did but I did not put in smiley face???
sh410
Northwest
Posted: 05/07/12 03:36pm Link  |  Print  |  Notify Moderator
If you edit your original post you will see colon between found and www.rv.net the colon W is equal to
pulsar
Lewisville, NC
Posted: 05/07/12 04:07pm Link  |  Print  |  Notify Moderator
The RV.Net server has had issues for a week now. Have you tired one of the other portals to the Open Road Forum? Try this one: Woodall's Portal
Oh, sh410 is correct about the smiley. When the display engine sees a colon or a semi-colon, it looks at the next character. If it is one on 17 in its "smiley dictionary" it replaces the colon and letter with a smiley
:W is animated wink
;) is just a wink
Note, I used a trick to display the characters. Copying or quoting this post will cause the trick to fail and the smileys will be displayed in their place.
Tom
On edit, changed to the correct character to get a
* This post was edited 05/07/12 05:08pm by pulsar *
IAMICHABOD
Sunny So Cal
Posted: 05/07/12 04:57pm Link  |  Print  |  Notify Moderator
thanks pulsar now i know some more tricks I will try again.
fla-gypsy
North Florida
Posted: 05/07/12 06:20pm Link  |  Print  |  Notify Moderator
I had some issues this morning with it as well with the error message.
enahs
Washington
Posted: 05/07/12 08:09pm Link  |  Print  |  Notify Moderator
Same problem here!
'07 Chevy 3500 Dooley, CC, LT3, D/A
IAMICHABOD
Sunny So Cal
Posted: 05/07/12 08:17pm Link  |  Print  |  Notify Moderator
I tried pulsar's suggestion and used Woodalls portal and it went right thru no problem
ginsc
summerville, SC
Posted: 05/09/12 02:28am Link  |  Print  |  Notify Moderator
new and wanted to test
pulsar
Lewisville, NC
Posted: 05/09/12 05:52am Link  |  Print  |  Notify Moderator
Welcome to the forum.
This is the form section for testing and asking about forum features. If you have problems, post here and we will try to help.
There are links to many tutorials in the FAQs at the top of this section.
Tom
