RV.Net Open Roads Forum: Travel Trailers: Breakaway cable
 > Breakaway cable
WI Bowhunter
Shiocton, WI
Posted: 05/07/12 06:40pm Link  |  Print  |  Notify Moderator
If it is a plastic pin, this is the replacement cable/pin with out the whole switch...Tekonsha pin/cable
These are rather quite common if it is tekonsha. Any trailer parts house should stock lots of these.
Keep the Shiny Side Up!
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
aftermath
Washington State
Posted: 05/07/12 08:40pm Link  |  Print  |  Notify Moderator
I needed to "re-do" mine with a longer cable. I went to HD and purchased the appropriate gage cable. They also had the little sleeves to crimp the whole thing together. I had a small vise that I carried out to the trailer and installed it without issue.
If you don't want the coiled cable, you can build your own.
2008 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Prodigy Controler
marc515
New Jersey
Posted: 05/08/12 05:05am Link  |  Print  |  Notify Moderator
Is there a DOT approved method to connect the cable to your tow vehicle?
What method do you guys find best?
The Tekonsha looks like its a stronger cable than the Fastway
Pictures are worth a thousand words and will be greatly appreciated.
Thank you.
Best Regards,....marc & joan
SolidAxleDurango
OK, USA
Posted: 05/08/12 04:03pm Link  |  Print  |  Notify Moderator
Gdetrailer wrote:
.. In PA, they CAN pull you over and not only issue you citations for any safety violations but they can impound your entire rig...
Hyperbole.
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
Gdetrailer
PA
Posted: 05/08/12 05:40pm Link  |  Print  |  Notify Moderator
SolidAxleDurango writes "Hyperbole. "
Nope, sorry.
PA state troopers do have the right to impound your rig. This could be anything from you leaving along the road until YOU fix the violations to you paying to have it towed to get it fixed. In other words your trip may take some unwanted twists and turns and an unwelcome forced stay.
PA troopers are empowered to make these decisions whether you like it or not.
But honestly you can't really mean you fail to connect your emergency breakaway?
That is just foolish and you are risking not only your life but other motorists.
Driving on the road is a privilege, not a right. Fail to follow the rules and something bad will happen.
SolidAxleDurango
OK, USA
Posted: 05/08/12 07:08pm Link  |  Print  |  Notify Moderator
Nope, sorry.
Until you show me ANY statute that would allow a trooper to impound a vehicle simply because the driver did not utilize a breakaway cable I stand by my assessment that you post hyperbole.
I welcome your proving me wrong.
 > Breakaway cable
