RV.Net Open Roads Forum: Fifth-Wheels: Jacking up 5er
 > Jacking up 5er
Page of 5
pitch black
newport, TN
Posted: 05/07/12 04:45pm Link  |  Print  |  Notify Moderator
Getting ready to replace all 4 tire on rig, should i trust tire dealer to jack up 5er and change them or just have them mount new tires, if i do it myself whats the safest and easiest way to get tires off the ground so i can put new ones on ? thanks
05 Chevrolet 2500HD 4x4 Duramax/Allison. 2009 Heartland Big Country 2950RK 5th wheel,prodigy controller, 18k Reese signature series hitch, Line X bed liner
pitch black
newport, TN
Posted: 05/07/12 04:55pm Link  |  Print  |  Notify Moderator
i also have the equa flex suspension, does that matter?
SkiSmuggs
Northern Vermont
Posted: 05/07/12 05:06pm Link  |  Print  |  Notify Moderator
Safer to do it yourself. I heard of folks having it done by a garage only to lose a wheel later because of over torquing by the air wrench weakening the studs.
2011 F150 Super Crew EcoBoost, Short bed, Max Tow, Truxedo Lo Pro QT, SuperSprings, Bilstein HD shocks, Reese 16K hitch.
2012 Cougar High Country HE 299RKS 5th wheel, Reese Sidewinder pin box
Sandia Man
Rio Rancho, NM
Posted: 05/07/12 05:17pm Link  |  Print  |  Notify Moderator
Had all 4 tires mounted and balanced on rims by Discount Tire and installed them myself using a jack under the spring perch. As mentioned above, it gave me the opportunity to service bearings and brakes.
donn0128
Pronounced Ore-gun
Posted: 05/07/12 04:56pm Link  |  Print  |  Notify Moderator
Place jack directly under springs. I just did it myself. Easier than pulling fiver to them. Besides it gave me a chance to adjust brakes and clean and wax the wheels.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Bionic Man
Colorado
Posted: 05/07/12 05:25pm Link  |  Print  |  Notify Moderator
The best way would be to jack the trailer up by the frame if it is possible. I've heard that there is the potential to bend the axle if you do it there.
And, as far as letting someone else do it, here is how my trailer looked the first trip after I had someone work on my wheel bearings/brakes. Lugs were not tightened properly and I lost the wheel.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
gmcsmoke
Butler
Posted: 05/07/12 05:28pm Link  |  Print  |  Notify Moderator
Since you have an equa flex you have to jack up by the frame.
agesilaus
North Florida
Posted: 05/07/12 05:47pm Link  |  Print  |  Notify Moderator
I've got four new rims coming in to fix the offset problem on my Titanium and I think that's what I'll do. I thought about running them down to goodyear but discount is closer.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
laknox
Arizona
Posted: 05/07/12 05:56pm Link  |  Print  |  Notify Moderator
Dunno, but Discount Tire jacked mine up directly under the spring perch and did both axles at the same time (one side only). If the spring perch can hold the entire trailer up without bending the axle, putting a jack under them shouldn't be a problem. I believe they also put a jack-stand under the frame as a safety. Their air wrenches are set to only torque to about 40-50 lb ft and the nuts are hand-tightened with a torque wrench to spec. Reminds me, I need to check mine again. :-)
Lyle
1936 John Deere Model A
pitch black
newport, TN
Posted: 05/07/12 06:00pm Link  |  Print  |  Notify Moderator
how far from wheels do you place jack? and what kind of jack? bottle jack or floor jack? thanks
Page of 5
 > Jacking up 5er
