RV.Net Open Roads Forum: Hybrid Travel Trailers: battery question for 2004 travelstar 21SSO
Open Roads Forum  >  Hybrid Travel Trailers
 > battery question for 2004 travelstar 21SSO
TheMonty's
New hampshire
Posted: 05/07/12 05:35pm Link  |  Print  |  Notify Moderator
Hi All,
First time blogger. I have 2 questions:
1. I remove the 12v battery 2 seasons agao from my trailer before I winterized it. Didnt use it last season. I want to reinstall a battery. I have 4 wires up at the trailer hitch end of the camper that attach to the battery, a red, a black, and 2 whites. Not sure what wires go to what terminal. Can anyone help? Electrical is not my strong suit.
2. Even when running of house power (without the battery installed), the motor for the "bumpout" doesnt work. Is it because the battery is not installed?
Any help would be greatly appreciated.
skipnchar
Topeka or somewhere else
Posted: 05/07/12 06:23pm Link  |  Print  |  Notify Moderator
slides almost always wire directly to the battery. What is pretty much the universal color for ground in an RV and MOST of the time any other color will be a positive connection.
terry thiessen
okla
Posted: 05/07/12 06:35pm Link  |  Print  |  Notify Moderator
Had same problem.my owners manual said conect two white wires to ground . Red and black wire to positive. I did it that way now slide goes out when I push in and in when I push out..
TheMonty's
New hampshire
Posted: 05/07/12 06:43pm Link  |  Print  |  Notify Moderator
im afraid if i dont get it right then i'll fry something else. then i'll have to get it to a dealer at $90/hr. cant seem to find any wiring disagram online and none of my owners paperwork has anything
pianotuna
Regina, SK, Canada
Posted: 05/07/12 09:36pm Link  |  Print  |  Notify Moderator
Hi,
Do you have a multimeter? If so check to see which of the cables goes to the ground on the trailer. Those will be the negative cables.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
TheMonty's
New hampshire
Posted: 05/08/12 04:14am Link  |  Print  |  Notify Moderator
how? do i measure from each cable to the trailer frame? what am i looking for on the multimeter?
get lost
NW NJ
Posted: 05/08/12 04:58am Link  |  Print  |  Notify Moderator
Set the multimeter to measure DC voltage and put one lead on one cable and the other lead on the other cable with the trailer plugged in. If the multimeter shows a negative voltage, switch the cables.
But on my 2005 21SSO the red cable is positive.
pianotuna
Regina, SK, Canada
Posted: 05/08/12 05:05am Link  |  Print  |  Notify Moderator
Hi,
Set it to read ohms. The cables with zero resistance to the frame are the negative leads.
Then set it to read DC volts and check to see if the voltage confirms the above.
Chuck_S
Broadview Hts, OH, USA
Posted: 05/08/12 05:38am Link  |  Print  |  Notify Moderator
Standard wiring is White-Ground, Black or Red-Positive. Usually easy to trace the white wire to a connector bolted to the trailer frame. There's often a data plate on the trailer frame near the battery box location denoting colors too.
The slide switch marked In/Out? Mine isn't marked. Goes one way or the other depending on which way I depress it. If it's marked In/Out reverse the wires at the switch, not the battery. You do NOT want a White wire connected to the Positive battery terminal or Red or Black to the positive terminal unless you want more confusion later on.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
TheMonty's
New hampshire
Posted: 05/08/12 05:59am Link  |  Print  |  Notify Moderator
To "get lost", on your 2005, is the red wire the only positive?
Damn I hate electricity!!
