Johnworth914
USA!
I just very recently right-sized from my 30' Class C to a Pleasureway Excel TS. I seem to be going thru propane at an alarming clip.
I have the small 3 way fridge which I usually run on propane. How long does your propane last running the fridge?
Maybe it's just that I'm used to the old big tank on my C and have not yet adjusted to the tiny tank on the PW.
Do any of you use hott rodds for your water heaters to save gas?
Thanks
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
goreds2
OH H ..... EYE OH !
Have you had a professional check for leaks?
See Picture In My Profile
1990 Dodge XPLORER RV Van- Purchased 10/15/10
Chick Magnet !
* Sportsman GEN154 2000 Watt 80cc Portable Generator *
XM Satellite Radio since 12/25/2004
Sold my Class C 1976 Dodge TEC Motor Home 9/25/10
Jayco-noslide
Galesburg,Il., USA
A 30 lb. tank last us 1 month, give or take a week.
Jayco-noslide
skipnchar
Topeka or somewhere else
30 lb bottle on my trailer will run just the fridge for a couple of months. USUALLY when running the fridge on LP I'm also heating water and cooking with gas so it's a rare occasion that it's just the fridge. Refrigerator has a VERY small flame and runs only a few hours a day under average conditions so it SHOUJLDN'T use much gas.
Johnworth914
USA!
goreds2 wrote: Have you had a professional check for leaks?
I had a leak test done when I bought it, but that does not mean its not leaking now.
But I don't think so. I have shut everything off for the past week and have been monitoring the tank, and it is not going down.
Road-Trekker
California
With the fridge on 24/7 (on propane), our 45 lbs. tank last us between 2-3 months depending on weather. It does last longer on colder season.
Roadtrek Agile SS: DIY Mods,Camping, and Travel Adventures.
Francesca Knowles
Port Hadlock, Washington
Doesn't anybody use heat????
In winter, using propane for fridge, cooking, and 12 hrs. a day for heat, a 20 lb. cylinder will last me about six days. (No water heater)
In summer a cylinder will run fridge and cooking (no heat) for about ten days.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
LadyRVer
With our Class B PW, it has a very small LP tank. I haven't used anything on LP in the 3 years we have owned it, but do know it has a small tank. Our Class A only has an 18 gallon tank, which is also small and I have just used the LP daily on a trip and the gauge went down about 3 gallons at the most for a week, with heat on in the mornings. Tank only fills to 80%. Using fridge on LP, WH on LP and a little cooking, IMO a tank every 10-14 days would seem about right for the size our PW Excel TS has.
PSW
Oklahoma City
"B" specifically, my Roadtrek is 10 US gallons, 45 pounds. It will last two weeks of boondocking. That is in the summer time, using heat in the mornings if we are in the mountains (which is where we normally camp in the summer), hot water heater, refrig and stove. I am always pleased at how long it lasts. Our previous two Bs were about the same experience.
PSW
2007 Roadtrek 210 Popular
2oldman
Winchester WA
Johnworth914 wrote: Do any of you use hott rodds for your water heaters to save gas? Assuming that's an electric element, no, I boondock to save money on campgrounds. Saves me a lot more money than worrying about burning gas.
