RV.Net Open Roads Forum: Toy Haulers: street motorcycle hauling
Search only in Toy Haulers
 > street motorcycle hauling
Page of 5
05extcabflare
PA
Posted: 05/07/12 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Just purchased river forest 27ulp toy hauler. I need to haul 2012 harley touring bike. Whats the best way tie the bike down without drilling holes in the floor for wheel chocks. Does anyone have pics.
JaredWPhillips
Henryville, IN
Posted: 05/07/12 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn't the toy-hauler have tie-downs built-in? I just used the four tie-downs to hold my motorcycle from four corners. Quality ratchet-straps pulling down four-ways; it wasn't budging.
TV: 2001 Chevy Silverado 1500 ext cab 4x4 5.3 V8. GoodYear Wrangler Authority E-Rated tires, FireStone AirBags.
TT: 2004 Gulfstream Amerilite 21MB
fj12ryder
Platte City, MO
Posted: 05/07/12 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Mine looks like this:
and this:
The bolts are countersunk on the bottom of the aluminum flat stock and protrude up through holes in the chocks. With the front wheel in the chock it the tie downs really only keep it from wobbling around with virtually no front fork compression. I also use a couple tie downs at the back to keep the rear end from walking around.
No need to drill any holes anywhere.
(EDIT: Resized images to fit the page.)
* This post was edited 05/07/12 10:00pm by an administrator/moderator *
Howard and Peggy
"Don't Panic"
05extcabflare
PA
Posted: 05/07/12 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Fj: Where did you the aluminum plates and wheel chocks? Did you make the plates?
fj12ryder
Platte City, MO
Posted: 05/08/12 05:56am Link  |  Quote  |  Print  |  Notify Moderator
The chocks are standard Condor chocks, and an excellent unit BTW.
I bought some flat 3/16" aluminum stock from a local metal supply shop, cut it to size, and had it welded. Then I slotted the holes for the D-rings, figured out the position for the chocks, and drilled the holes. Then I threaded the holes, countersunk the underside, and installed flat head allen bolts.
I got the idea from another guy on here who had done something similar.
1jeep
acushnet ma.
Posted: 05/08/12 06:00am Link  |  Quote  |  Print  |  Notify Moderator
I dont have a toy hauler, but the few times i have had my HD in the bed of the truck i would put a 4x4 and 1x4 block of wood under the frame at the engine. Then hook my straps to the fram at the crash bars, the wood acts as a stop so you dont over compress your forks.
Also you didnt mention which model HD, but i know my ultra has rubber mounted handlebars so i would strap to them.
My fathers TH has tracks in the floor which allow for hook points, he also puts some wood under the frame and then straps till the bike is sitting on the wood.
2011 F250 CC LB, 6.7 urine injection
2007 keystone Outback Sydney 32BHDS
2009 HD Ultra CVO
2013 CanAm Outlander 1000
1963 Wife..no mods
shagan77
Ozarks
Posted: 05/08/12 07:39am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't strap to the handlebars. Kuryakyn makes some really nice frame mounted Tie-Downs
that work far better than the handlebars.
The aluminum frame system is cool. I just added a second row of tie downs to the RV floor, (made sure all the back sides were indeed through frames and added nuts/washers to them) I also positioned my chocks (not as nice as the Condors) and drilled holes in the floor. I then inserted threaded inserts into the floor (gorilla glued) so I can simply remove the chocks when I arrive and toss a rug over the floor. No bumps and simple. When I tie down I use the triangle method, a strap from the Kuryakyn tie down bracket to the front d-ring and one to the d-ring just behind the bike front floor boards. I usually haul 2 Ultra's and they've never moved.
2013 Sierra Denali 3500 Duramax\Dually
2011 Cyclone 3950 HD
2009 Harley Davidson Ultra Classic
2011 Can-Am Spyder RT-S Limited (DW's)
Usually a keg of beer....
TxTiger
North Texas
Posted: 05/08/12 08:48am Link  |  Quote  |  Print  |  Notify Moderator
I have a fabricated setup similar to fj12ryder, and got my idea from him based on his pics. I did mine cheaper however by using Harbor Frieght motorcycle stands (less than $70 each), not the chocks. The stands have a wider stance than the chocks and have built in tie rings. I bought a piece of aluminum angle from the metal yard and fit it between and attached it to the two front d-rings. I attached the two stands to the angle and so far so good. It's a fast set-up and take down once the bikes are unloaded. My next fabrication will be an electric winch set up to winch my bikes in when I have a steep angle on the ramp. Lighter bikes go in ok but heavier ones require someone pushing at the rear as you power it up the ramp, or the rear wheel spins and the bikes starts going sideways, not fun and always intimidating.
http://www.harborfreight.com/motorcycle-stand-wheel-chock-97841.html
Good luck.
2000 F250, 7.3 PSD, 6 speed manual, CC, SB
KZ 27TH Toy Hauler, 5,700 lb dry weight/8,000 lb GVW.
2010 Triumph Tiger 1050
2012 Triumph America
2009 Suzuki DRZ 400sm
Billieg2
Gone from this forum
Posted: 05/08/12 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Just bought a toy hauler almost brand new. Put my bike in back and tied it down with 4 straps so tight it was like it was welded to the floor. 40 miles later I stopped at a rest area and checked on it. It was over on it's side with the handle bar going through the wall...
I have always used a wheel chock and never had any problems but I just bought this away from home and couldn't put one in till I got home. It now has a harbor freight locking wheel chock.
Unless you want to destroy your bike and toy hauler a locking wheel chock is the only way to go with 4 straps.
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
LowRyter
OKC
Posted: 05/08/12 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I use Harbor Freight wheel chocks. Instead of bolting it to th floor, I strap it down with ratchet straps like I use on the 4 corners of the bike using the same eye hooks in the floor. I also use rubber entry mats under the chock to protect the floor.
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
Page of 5
