RV.Net Open Roads Forum: Class A Motorhomes: Are my house batteries sick?
 > Are my house batteries sick?
Larry Cohen
Mobile, AL
Posted: 05/07/12 07:09pm Link  |  Print  |  Notify Moderator
They should be....original from a 2005 install...Interstate 6v deep cycle...after road running for 3 hours with the genny on and being fully charged before hitting the road, I noted my Intellitec display showing 12.3-12.4 volts with the engine and genny off and the residential fridge running...I don't have a hydrometer to check acid state and haven't equalized for over a year...What should normal voltage show with a fridge running? I'm suspecting my house batteries might be near the end of the road
2006 Mountain Aire 43
Short haired wife, long haired daschund and 3 sugar gliders are co-pilots, along with Garmin Nuvi 855
05 Honda Pilot with Air Force One supplemental brake
Blue Ox Aventa II towbar
Whirlpool Residential Fridge !!!
garym114
Bluff Dale, Texas
Posted: 05/07/12 07:20pm Link  |  Print  |  Notify Moderator
I don't think anyone can say what the voltage should be under load but that doesn't sound to bad. How many amps does the fridge draw?
Larry Cohen
Mobile, AL
Posted: 05/07/12 07:30pm Link  |  Print  |  Notify Moderator
"How many amps does the fridge draw"
about 1-2 after starting...the amp draw on the display showed about 14..don't know from where
pianotuna
Regina, SK, Canada
Posted: 05/07/12 07:57pm Link  |  Print  |  Notify Moderator
Hi,
If the amps draw was 14 then 12.3 is a good number.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
flyswamper
Calgary, Alberta, Canada
Posted: 05/08/12 08:00am Link  |  Print  |  Notify Moderator
Pssst.... Hydrometers really are very inexpensive....
Constructive disagreement is encouraged. It is how I/we learn!
Dad,Mom, & 3 young'ns
Current Home (Calgary)
MountainAir05
New Mexico
Posted: 05/08/12 09:06am Link  |  Print  |  Notify Moderator
check voltage with a good meter on the battery. All the other gauges reading are for a referance only.
Wherever I happen to park
Posted: 05/08/12 11:00am Link  |  Print  |  Notify Moderator
I would agree with the 12.3 number.. If you have a progressive dynacic s converter then you equalize normally.
Also, if it's s workorse the alternator does a fair job (not a great job) of equalizing.
I would check fluid level (HINT: It is not water, you add water but it mixes with what is in there and that is NOT water) and clean the connections,
Also check the other ends of the wires epically the ground lead.
This is ... Normal maintenance.. Nothing special.
