RV.Net Open Roads Forum: Class A Motorhomes: Headlights very dim...
 > Headlights very dim...
thestarfinder
Mount Gretna Pa.
Posted: 05/07/12 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
2001 Monaco Windsor with very dim head lights.....Where can I get there at a good price and much brighter if possible....Thanks Tom
Exist Responsibly.........
fcooper
Richmond Hill, Georgia
Posted: 05/07/12 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
You will find a lot of good information in this thread on IRV2
Discussion of repair dim headlights
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
docj
Fulltime--Home is where we park it
Quite a few Class A MH's have the same problem you report as the result of voltage drop in the headlight switch and the long length of wiring through the switch to the lamps. A common fix to the problem is to install a relay with heavier gauge wiring which is controlled by the headlight switch.
Almost any RV service facility should be able to do this for you.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
rvrepairnut
bc
Posted: 05/07/12 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Install a Hi-Intensity headlite kit.U can buy them online quite reasonable and they are the answer
fordsooperdooty
Posted: 05/07/12 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
Sylvania makes a whole line of SilverStar Headlight Halogen bulbs that give a brighter and whiter light output.
jauguston
Bellingham, WA
Posted: 05/08/12 08:09am Link  |  Quote  |  Print  |  Notify Moderator
The first thing to do is check the voltage right at the headlight. As others have said low voltage due to insufficient wiring is VERY common. If the voltage is much lower than the voltage at the battery posts the relay fix with 10-12 ga wire direct to the battery through 30a bosch relays will make a world of difference. There are ready made headlight relay kits on the internet.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
vtbigdog
VT, GA
Posted: 05/08/12 08:16am Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem. The headlights on my coach were BMW-issued so I knew they should be brighter. On my coach and on most coaches, the power for the headlights runs from the fuse panel, up to the headlight switch and then to the headlights. The voltage drop is severe which makes it look like the bulbs are dim. You also develop a lot of heat on the headlight switch...and I mean a lot.
I installed a set of relays for the low and high beam. It works as follows. the relays are connected to the battery and are fused. The low beam relay is wired to both low beams and the high beam relay is mounted to the high beams (I have separate headlights for high and low beam). The headlight switch is then wired to the high and low beam relays. When you turn on the headlights, the voltage from the switch activates the relay which in turn turns on the headlights. The amount of voltage from the headlight switch is minimal now because the switch is not energizing the headlights...it is only turning on the relay. So the headlight switch does not overheat. The headlights are now as bright as they should be.
Also on my coach, when the high beams were activated, the low beans would turn off. I added another relay that would allow both headlights to illuminate when the high beams were on. There is a ton of light now.
The relays and the low/high relay were all purchased through LMC Truck.
Richard
2003 Safari Trek 3011
8.1 Workhorse/Allison
kdk
usa
Posted: 05/08/12 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Another option is to convert them to "HID". Just google HID covertion kits and get a cup coffee for some reading. Just make sure you get a quality kit from a reputable dealer. Did my (dim) 60mm projection lights a couple of years ago and never use the brights any more.
KDK
06 Holiday Rambler Ambassador
11 Buick Lacross
bmerpaw
1000 Islands Ontario Canada
Posted: 05/08/12 08:43am Link  |  Quote  |  Print  |  Notify Moderator
X2 on HID kit. $60. for the kit & $40. for installation by a qualified installer. Now I can see down the road night or day.
2004 Newmar Dutchstar 4009, Cummins ISL375
2005 Jeep Liberty Toad
Traveling Man
vtbigdog
VT, GA
Posted: 05/08/12 10:18am Link  |  Quote  |  Print  |  Notify Moderator
If you do not have 12V at the headlight, no bulbs new or otherwise will be very bright. You can check the voltage yourself...make sure to check the high beam voltage as those use more juice.
