RV.Net Open Roads Forum: Class A Motorhomes: Headlights very dim...
 > Headlights very dim...
Ames
South Central Florida
Posted: 05/08/12 10:50am Link  |  Quote  |  Print  |  Notify Moderator
A Beaver Ambassador Club Member posted the fix for dim headlights on his Beaver. Youtube has several vidios on the modification you may need to do to get brighter headlights.
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 2012 Dodge Durango RT AWD Hemi
thestarfinder
Mount Gretna Pa.
Posted: 05/08/12 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all for responding......You folks are so very helpful!!!!!
I will do some research and fix the issue.....
Exist Responsibly.........
thestarfinder
Mount Gretna Pa.
Posted: 06/01/12 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the great info folks..... What I did was upgrade the bulb it self...It was a Phillips bulb(I think it was original from 2001)And got a turtle wax cleaning kit for the lenses.....It seems like it is going to take care of the issue,didn't get to try them while driving but here at the campground they are very brighter.......Thanks Again,Tom
wny_pat
Western NYS
Posted: 06/01/12 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Read: http://www.danielsternlighting.com/tech/relays/relays.html
03 RoadKing
Summerfield NC 27358
Posted: 06/01/12 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Being your MH is a 2001, the first thing I would check would be the ground. A poor ground will cause dim lights.
Jim and Deb
The Furchildren Abby and Baylee
USAF Retired
2001 Newmar Mountain Aire
ryanallie1
Magalia, Calif
Posted: 06/02/12 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
On our Motorhome, it was a very simmple fix. We also had "Dim Headlights". But after checking everything with a Muti-Meter, ours turned out to be very dirty, rusted ground Wire.
We were lucky. I only had to remove the Ground Wires, clean the connectors and clean the spot where it was Grounded, by sanding the metal of the frame back to a nice shinney spot.
Headlights work perfectly now. Sure glade I do all of my own repairs. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
