superglue
phoenix
when using the refer on propane does it use any battery power? and if it does is the power usage that much or if your house batteries are not that good should it sustain the refer for overnight?
have 2 6V batts for house batteries and so far they do start the engine since my engine battery is shot.
its a 2004 fleetwood class A
bob213
Fresno, CA
Batteries run the circuit board and interior light on the refrig. Should not be that much of a draw. If it's that questionable, turn the refrig. off at midnight and start it back up in the morning. If it's cool outside and you are not opening it, it should maintain a safe temp. overnight.
CA Traveler
The Western States
superglue wrote: when using the refer on propane does it use any battery power? and if it does is the power usage that much or if your house batteries are not that good should it sustain the refer for overnight?
its a 2004 fleetwood class A Replace the chassis batteries and have the house batteries load tested. Until you have operational batteries all bets are off and in your case you will soon not be able to start the engine.
I agree with the above poster: The refer uses very little battery power to run on propane - but there might be fans or heaters that take more than a very basic refer.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
hottubkid
SCHAUMBURG,IL
FYI I have replaced all bateries on my 2004 southwind
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
CA Traveler
The Western States
duplicate
hottubkid
SCHAUMBURG,IL
The refer is run on the house batteries. But if you keep starting your engine from the house batteries it takes a lot of power from the house batteries. I'd spend the extra for the engine battery.
tempforce
Pacific Wonderland (in the summers)
the house batteries are deep charge, they are not designed for a full start load. you will be buying all new batteries if you keep stressing the house batteries.
get the engine batteries replaced...
and the fridge uses very little power to run the circuit board and light.
less if you don't check the light very often...
somewhere in the texas 'lost pines'
'08' Dodge mega limo-cab, 409, kelderman rear air ride, max brake controller.
'02' 34' Holiday Rambler TT, the Gypsy Wagon.
'83' Ford Ranger with a 2.2 Diesel, little smoke
'56' F100 project truck
John & Angela
Full Timers in Canada, USA and Mexico
The Gas valve also uses 12 V to open when the fridge board calls.
2003 Revolution 40C Class A. 2002 Vanguard 22 foot Class C. Diesel smart car Toad or pulling a 2009 Timeout Tent Trailer.
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
wolfe10
John & Angela wrote: The Gas valve also uses 12 V to open when the fridge board calls.
As does the igniter and the very small amount for the PC board.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
BobR
Aurora, Illinois
Running on a dead chassis battery is not good for the alternator.
