RV.Net Open Roads Forum: Truck Campers: 11 ft camper and horses?
 > 11 ft camper and horses?
usmcshepherd
Louisiana
Posted: 05/07/12 09:19pm Link  |  Print  |  Notify Moderator
All,
We are looking to go back to a Lance from our 5th wheel when I return from Afghanistan next year and are looking at either a Lance 1181 or 1191. That said, we've discussed getting back into horses as well. My question for those with large campers (11ft variety) is can you haul a horse trailer with that large of a camper? Anyone have any experience with that kind of a setup?
Thanks
2011 Ram 3500/2012 Jayco Pinnacle 36 REQS
Semper Fi
MGySgt/USMC
jimh425
Western WA
Posted: 05/07/12 09:22pm Link  |  Print  |  Notify Moderator
You'd probably be better off with a drw. But that's a pretty common scenario.
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
Buzzcut1
Norcal
Posted: 05/07/12 09:33pm Link  |  Print  |  Notify Moderator
you rang?
03 F350 Diesel 4x4 Crew Cab long bed, 08 Lance 1055, Rancho 9000xl, Air Lift air Bags, Torqlift tiedowns,stable loads, super hitch, 48" super truss, Toyo 285/75R16 Opencountry HT
jmtandem
western nevada
Posted: 05/07/12 09:34pm Link  |  Print  |  Notify Moderator
Agree with the previous comment about the dually. As to how much horse trailer you can tow, that is dependent on the distance from the receiver on the stinger and how much trailer you will need. The Lance brochure has a handy table that provides information about trailer tongue weight and trailer weights that can be accommodated as the distance from the reciever increases up to about 48 inches. There is a dramatic reduction in trailer weight capacity with the very long 11 foot campers.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
usmcshepherd
Louisiana
Posted: 05/07/12 10:02pm Link  |  Print  |  Notify Moderator
I have a DRW Dodge 3500 now so that I've got that covered. I've read that trailer toungue weights out to 48" is only about 500-600lbs...my problem is I have no idea what the trailer tongue weight would be on a 2-3 horse aluminum trailer.
hmknightnc
Wilmington, NC
Posted: 05/07/12 10:17pm Link  |  Print  |  Notify Moderator
I would suggest a living quarters 3 horse gooseneck trailer. Can make an awesome toyhauler as well as the horse trailer frame is significantly stronger built than a traditional toyhauler FW
Buzzcut1
Norcal
Posted: 05/07/12 10:27pm Link  |  Print  |  Notify Moderator
if you use a weight distributing hitch with the 48" super truss the load carrying capacity at the ball is 1200 pounds. http://www.torklift.com/t.php?w_page=supertruss
a bumper pull trailer tongue weight is usually 10-15% of the trailer weight
usmcshepherd
Louisiana
Posted: 05/08/12 02:04am Link  |  Print  |  Notify Moderator
Thanks for the input from all. As we are probably going to travel the majority of the time without horses right now (small children), we will probably favor the Lance/trailer combo vice living quarters gooseneck. I did check the torklist site that Buzzcut1 recommend. The trailer I am looking at weighs less then 4k lbs so even with three horses we'd be well under 8k loaded so that setup would work perfectly.
bka0721
Republic of Colorado
Posted: 05/08/12 10:55am Link  |  Print  |  Notify Moderator
I vote for the 1191, as it has the side entrance. Obviously, you can unhook the trailer, but it sure makes it easier to have the side door. Especially with those pesky kids that seem to need to get in and out, in and out, in and out of a camper.
There are lots of discussions on rear hitches and the types you might need. A simple search will provide lots of helpful information on that topic.
My 14' trailer is over 5k, on the axles, but that weight does not shift. (Picture in signature). The question might be better in how well your transmission and rear gearing might be prepared for pulling/carrying your extra weight and the limiting factors your set up currently possesses.
I still have a Living Quarters 48 ft Gooseneck trailer and the limiting accessibility of that trailer, convinced me a truck camper was the best direction for me to move towards, for my adventures.
Thanks again for your service and we all look forward to your safe return.
b
08 F550-4X4-CrewChas-6.4LDiesel-206"WB GVWR17,950lbs
09 Lance 1191
600w Solar~8-6vGC2 928AmpH~Tri-Star45/4 MPPT
Xantrex 2000W
300w Solar~2-6vAGM 240AmpH~Tri-Star45/4 MPPT
Xantrex 1500W
08 BMW R1200GS Adventure
09 7X14 Enclosed Haulmark Trailer
elkhornsun
Monterey
Posted: 05/08/12 04:40pm Link  |  Print  |  Notify Moderator
You are crossing over into diesel territory with a large and heavy camper pulling a 8,000 lb. load. A gas engine with a 4.10 rear end will be near its limit with this gross weight but you will have 4000-5000 lbs. to spare with a new 1-ton. With a live load the control issues are as you know different then with a static load like a boat or TT.
I would also want the exhaust braking that is only available with a diesel engine. Good review of 2012 trucks pulling trailers in tests at Car & Drive, and 2011 1-tons pulling 19K loads (but with nothing in the box) at mrtrailer.com.
