jerem0621
Sequatchie, TN
Is there a way to wire up my F-350 to supply 30 amp power to my travel trailer to run the ac while towing?
No, I don't want people in the TT while towing. But it would be nice to flip a switch on the dually about 50 miles away from camp so that we can set up in a cool camper. Or so we can stop at a rest area for a while and have ac.
Probably crazy but I figured it's worth it to ask.
Thanks!
Jeremiah
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Old-Biscuit
Across the USA
A/C operates on 110V AC power......your truck supplies 12V DC power.
The battery charge line thru your 7 pin connector can barely recharge the TT batteries while towing.
Now if you had a 3000W generator in back of truck, power cord connected to TT, A/C set to 'on', time delay relay with remote start on generator.......
OR just turn on A/C when you get to destination and have power hooked.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Mr Bojangles
Hamburg, PA. 19526
Old Biscuit and jerem0621:
Reading this posting got me thinking:
I have a 3000 Watt generator and a small TT...........
And believe it or not I'm reluctant to "PULL THE CABLE OUT OF THE SIDE BOX" and connect to Generator sitting in P/U truck at back of truck.
It's always a "pain" to push cable BACK into Storage "BOX".
I carry three (3) batteries, and very seldom use generator because of my dislike for above task.
Sooooo.... why can't I pull this cable out of "BOX" and LEAVE it out, securely mounting cable from "BOX" hole onto side of TT, running cable across tongue and into back of truck plugging into Generator?
Now at each stop all I must do is turn generator switch to ON position. Forsee any problems?
I could look to bring "another" AC cable thru front wall of TT and leave AC cable in BOX alone someday....
SAFBVET.....
the_happiestcamper
Mount Pleasant, SC
Put a MaxxAir on your roof vent and leave it open while towing - that will help some.
Jon, Freesi, Lars, Tucker, Holland
2003 Yukon XL 2500 8.1L 4.10 axle
2010 Dutchmen 28G-GS
CG's we've been to
eHoefler
ozark mountains
the_happiestcamper wrote: Put a MaxxAir on your roof vent and leave it open while towing - that will help some.
This is what we do. We have 2 on our coach with fantastic fans. Keeps the coach cooler than you would think going down the road in 100* heat.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
ScottG
Bothell Wa.
Not really any practical way to do it. But you could secure a genny someplace on the truck or trailer to keep it going. A gen with low oil shutdown probably wouldn't work well though as any hill would shut it off.
Scott, Grace and Wesly
H0NDA eu2000i
45Ricochet
North Idaho
One word. Onan
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
tvman44
Southwest Louisiana
Generator on the back of the trailer is what we do.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
rjstractor
Auburn, WA
ScottG wrote: A gen with low oil shutdown probably wouldn't work well though as any hill would shut it off.
Never had an issue with either my MH generator or the Hondas we have installed in our fire engines. Both have low oil shutoff but never had one shut down even on a steep hill.
