outcampinagain
TT
So I want to do a little embroidery this summer while out at my campsite...I believe we are on 30amp service (private meter) does anyone know if running my home sewing/embroidery machine can be done while the a/c is running and not blow the electric?? Crazy I know but I can make a couple extra bucks on the road if this will work....
docj
Fulltime--Home is where we park it
Somewhere on your sewing machine there is a plate which tells its current and/or wattage requirements. I suspect that it is in the range of at most a hundred watts or so (1 to 2 amps) which would not present a significant electrical load.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
Jackthewonderdog
United States
It will be fine
HSIKES
Wilmington,NC
My Bride takes hers (Bertina 730) every time we go camping. It does not draw any excessive amount of current.
Enjoy it
Poppy
Horace & Bobbi
DRAKE - Yellow Lab (rescue dog)
2005 Fleetwood Providence 39 L; 4 slides; 350 Cat
2000 Saturn LW TOAD
2009 Buick Enclave CLX 2
Preach the gospel at all times. And if necessary.....use words.
outcampinagain
TT
Glad to hear it! Thank you for your replies!
Kittykath
Minnesota
I take my sewing machine everywhere I go! I usually sew at the picnic table and get some odd glances. Oh well, I'm also making a few $$. I'm keeping my fingers crossed that my DH will get me an embroidery machine for my birthday in June!
I've never had an issue blowing the electric even with the furnace, lights, TV and coffee maker on too. I love camping!
outcampinagain
TT
Kittykath wrote: I take my sewing machine everywhere I go! I usually sew at the picnic table and get some odd glances. Oh well, I'm also making a few $$. I'm keeping my fingers crossed that my DH will get me an embroidery machine for my birthday in June!
Me too! And it just keeps getting better!!
Hope you get the embroidery machine Lots-O-fun but very addicting!
Tothill
BC
outcampinagain wrote: So I want to do a little embroidery this summer while out at my campsite...I believe we are on 30amp service (private meter) does anyone know if running my home sewing/embroidery machine can be done while the a/c is running and not blow the electric?? Crazy I know but I can make a couple extra bucks on the road if this will work....
It will depend on how much draw your sewing machine has, check the specs, they should be on the machine. There are a number of people on this site who do sew while rving. The initial draw when you start the machine could be a problem.
Keep in mind that usually when you are sewing you also need to have a iron on and that would most likely be too much draw. I cannot run my sewing machine and iron off the same outlet.
What about sewing early in the day when it is cooler? You could run the AC to cool down the RV, turn it off then do your sewing. Run the AC long enough to cool things down again as needed between projects.
If you slow down the stitch rate it may reduce draw.
Valkyriebush
Yuma/Port Townsend
My wifes Pfaff 2170 and laptop draw very little amps. You will be fine. She sews and quilts the whole time we are on the road and at home.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
JiminDenver
Denver, Co
You could always run a cord from the pole for additional loads
2007/2003 Ford Expedition
Nights camped in 2011 21
Nights camped in 2012 16
