RV.Net Open Roads Forum: Travel Trailers: Our first TT campout
 > Our first TT campout
Dega500
Alabama
Posted: 05/09/12 08:26am Link  |  Print  |  Notify Moderator
Thank you all for the suggestions and well wishes. We were parked near the CG bathhouse and will likely use their faclities whenever possible but we wanted to try and use everything in the TT just to get a feel for it. We actually have two plastic tubs that I've had for years when "camping" that fit the sink perfectly. We used these after it became obvious we had filled the gray tank. We began pouring this in the black tank (another helpful tip I picked up here on RV.net).
Oh, one other observation that I failed to mention is how surprised I was at how far 6 gallons of hot water will go. This actually leads me to believe that the showers didn't do as much to fill the gray tank as letting water run in the sinks while cooking, washing dishes, brushing teeth etc...
MegaJohn
NW Geogia
Posted: 05/09/12 10:50am Link  |  Print  |  Notify Moderator
As others have mentioned... In addition to conservation, a portable tank for dumping would allow you to easily empty your holding tanks. Thedford & Barker are the two big players in this field, though you could use a 5 gallon bucket for unloading gray water... some campgrounds might allow you to run gray water into the woods, though this is typically discouraged due to sanitary & environmental concerns.
Happy Camping!
John.
Stock 2006 Dodge Ram 3500 MegaCab, 5.9L Cummins, Automatic, 2WD, Dually
- 30' 2006 Pilgrim Interntional travel trailer, dry weight ~7k pounds, GVWR ~9k pounds
- Husky weight distributing hitch, friction anti-sway control, electronic brake controller
Kat52
Arizona
Posted: 05/09/12 10:56am Link  |  Print  |  Notify Moderator
bedell wrote:
Welcome! Finding these forums is your best move so far. Don't stress out too much about the gas mileage. You are hauling a hotel suite and a restaurant with you after all. Enjoy your travels.
I have an extra "gray water hose" with cap on it to drain my gray water tank at night at the campgrounds. I usually look for a bush or woodline or foilage that need watering. I usually empty it late at night so that it is not bothering any other campers during the active daytime hours.
MegaJohn
NW Geogia
Posted: 05/09/12 10:54am Link  |  Print  |  Notify Moderator
Dick_B wrote:
I'm thinking we should use the term `RVing' when we stay in a hard-sided rig and `camping' when we stay in a tent.
To each his own... I'm sure tent campers would say the same about any setup with wheels.
When I hear "RVing" I think of posh RV resorts. I understand some enjoy stays at a CG with lots of activities for the family, but for me, I prefer to stay/camp in the woods... mostly outside.
Happy RV/Tent/Pop-up/cabin Camping!
John.
CavemanCharlie
Storden,MN
Posted: 05/09/12 11:26am Link  |  Print  |  Notify Moderator
Since I usually only go out for weekends I put my dirty dishes in a plastic tub, haul them back home, and run them through the dishwasher. While the dishwasher is running I repack the trailer with clean dishes out of my home cupboard.
I also use paper plates and cups a lot.
passport2590bh
Posted: 05/09/12 11:49am Link  |  Print  |  Notify Moderator
Hold on....
Ok. Now I'm ready.
2006 5.7L Ram 1500 Hemi Mega Cab
2011 Keystone Passport 2590bh GT
Bit Bucket
Brookings, Oregon
Posted: 05/09/12 12:44pm Link  |  Print  |  Notify Moderator
passport2590bh wrote:
Hold on....
Ok. Now I'm ready.
We usually camp next to the river so we just run our hose straight into the water. It gets diluted quickly that way...
sheltonlp
Washington State
Posted: 05/09/12 01:07pm Link  |  Print  |  Notify Moderator
Hold on....
Ok. Now I'm ready.
I'll bite...almost all the campgrounds in my area have a stricked policy against this, the fact that you do it after dark leads me to believe you know it's wrong. You do what you will but you shouldn't be advising someone new to RV'ing to follow your bad example.
There I'm off my soapbox :-)
2012 Evergreen Everlite 32RBK-DS
2011 Toyota Tundra 5.7 Rock Warrior
