RV.Net Open Roads Forum: Tow Vehicles: Would you tow with this veichle?
Search only in Tow Vehicles
 > Would you tow with this veichle?
Page of 5
Dreamsbride
Kelowna
Posted: 05/08/12 10:44am Link  |  Print  |  Notify Moderator
Hi.
My husband and I just purchased a used 2006 Jeep Liberty 3.7 4x4
We did this to replace our 2005 Dodge Caravan as a tow vehicle for our 2010 Jayco 1007 series pop up with following specs
Length (ft/ft) 20
Length (ft/in) 10
Height (closed) (in/closed) (ft/closed) (mm/closed) (m) 58 / 4.8 / 1473.2 / 1.5
Dry Weight (lbs/kg) 1710 / 775.7
Payload Capacity (lbs/kgs) 840 / 381
GVWR (lbs/kgs) 2550 / 1156.7
Hitch Weight (lbs/kgs) 190 / 86.2
Of course the dealer assured us that the van would pull this trailer no problems so we purchased the trailer. THEN we started talking to others and doing more in- depth research and discovered that the van transmission is not strong enough if we wanted to pull through the Okanagan Valley etc.
The Jeep shows a tow rate of 5000lbs and from what we have been told by talking to people that this would make a good tow vehicle for our trailer, so we purchased on this past weekend.
Now I am getting nervous because I have been reading forums etc about towing etc..and am getting mixed messages as people say they would not tow anything with the Liberty because of the small wheel base..I do most of the towing and most times I do it alone with just my daughter and the dog when hubby can't join us. Am I safe here ?
VintageRacer
Dundas, Ontario
Posted: 05/08/12 10:55am Link  |  Print  |  Notify Moderator
I think you'll be very happy. That is quite a small trailer, which should suit the jeep very well.
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
naturist
Lynchburg, VA
Posted: 05/08/12 11:02am Link  |  Print  |  Notify Moderator
You will have no problems. I have a Liberty diesel, and tow a 21 foot, 5,000 lbs gross weight, full height TT without issue. Your trailer is much lighter and has less wind resistance, so those nay-sayers who are telling you the Libby can't do the job can be dismissed as know-nothings.
Your gasser weighs over 4,000 lbs. and while it doesn't have the wheelbase length of a long bed pickup, it is plenty long enough for that trailer. Jeep says 5,000 lbs gross weight and 24 feet max length. You are well under the limits on both.
sgip2000
Oregon
Posted: 05/08/12 11:03am Link  |  Print  |  Notify Moderator
The biggest difference you'll see is the Jeep is RWD and the van is FWD. RWD is better for towing. That is why the Jeep has a higher tow rating.
I tow with an older Jeep Cherokee that has a similar weight and wheel base as the liberty and it does fine with a similar weight.
bgum
South Louisiana
Posted: 05/08/12 11:08am Link  |  Print  |  Notify Moderator
Just use sway control keep it at or under 60MPH and you should be fine.
rfryer
Phoenix
Posted: 05/08/12 11:22am Link  |  Print  |  Notify Moderator
I would try towing it carefully to see how it handles. I'd especially be alert for any indications of sway. I towed a Coleman PU with my 1973 Bronco, a short wb vehicle, and it was excellent. But my PU was smaller and lighter than yours and my Bronco has the 302 engine.
On the other hand, a friend pulled a small TT, maybe roughly 12', with a Toyota Land Cruiser, very similar to the jeep, and it jackknifed on him and scared the devil out of him. And I picked up a guy on I-17 with a 16' TT just like mine that jackknifed his, pulling with a Bronco II.
So I don't want to imply it's dangerous, I'm just a little wary of pulling much weight with small, short wb vehicles until I've assured myself they handle it OK.
Gman22
Burlington, Ontario
Posted: 05/08/12 11:29am Link  |  Print  |  Notify Moderator
I think you'll be fine with a PUP. If you start looking at full height hard-sides, you'll not be happy with the little Liberty for long.
2000 Coleman Bayside
2006 Ford Expedition Ltd. 5.4 L/3.73
APT
SE Michigan
Posted: 05/08/12 11:38am Link  |  Print  |  Notify Moderator
The minivan should have been plenty enough (with a good transmission cooler) for nearly any popup. The Liberty will be fine too.
2012 VW Passat TDI
dodge guy
Bartlett IL
Posted: 05/08/12 11:41am Link  |  Print  |  Notify Moderator
The problem is you are listening to other people instead of going by what the vehicle is capable of! either vehicle will tow a PuP just fine. you can add a friction sway control to the PuP and Liberty and it will tow stable provided yoiu have the proper tongue weight.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
skipnchar
Topeka or somewhere else
Posted: 05/08/12 12:26pm Link  |  Print  |  Notify Moderator
Manufacturers usually know pretty well what their vehicles are capable of. Stay under the tow ratings and MOST importantly, stay below the safety ratings (GVWR and GAWR) and you should be fine.
Page of 5
