RV.Net Open Roads Forum: Travel Trailers: What do you park on at home?
 > What do you park on at home?
gotharper
Cheraw, SC-The Prettiest Town In Dixie!
Posted: 05/08/12 12:04pm Link  |  Print  |  Notify Moderator
So we have just bought our first TT. We don't have enough driveway room at home to keep it on concrete. So in the back yard it will go. Someone that works with my wife says we should pour a concrete pad to park it on. Some just park in the grass, i've seen cement blocks under tires and some just treated wood........those of you that have been doing it a while....what do you suggest???
2004 28' Four Winds Express
2005 Ford F-150 SuperCrew 4x4- SOLD
2002 Ford F-250 Crew Cab 4x4 Powerstroke
2010 Ford Fusion DW's ride
2006 Club Car lifted
RoyB
King George, VA
Posted: 05/08/12 12:12pm Link  |  Print  |  Notify Moderator
I have one in a back driveway and the POPUP just sits in its spot on the grass (Used to be grass that is)
I thought about just paving a couple of strips where the tires would go but never did it... Probably not all that good for the tires to sit in dirt all the time...
Those paver things you see at LOWES should work. They are expensive however I guess... Truck load of Crush and Run rock used to cost a couple hundred - who knows what that has gone up to now...
I need to make me a couple of rock filled ten-foot tire runs to sit my POPUP on too...
You wouldnt think a couple rolls of these patio pavers would cost all that much for about ten feet just where your trailer tires are..
Dont know if the weight of the trailer would always be pushing these in the ground or not...
* This post was edited 05/08/12 12:32pm by RoyB *
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
K Charles
Connecticut
Posted: 05/08/12 12:14pm Link  |  Print  |  Notify Moderator
On the grass or dirt but it doesn't stay their long.
fordsooperdooty
Posted: 05/08/12 12:35pm Link  |  Print  |  Notify Moderator
If possible, during storage the tires should not make contact with grass, sand or the ground. Tires in contact with ground moisture will be more likely to be damaged.
Keep them covered to prevent UV amd Ozone damage, and try to drive the vehicle short distances to help distribute the natural waxes that the tire manufacturers add to the rubber...it keeps the rubber from cracking and aging.
Also keep them fully aired up to the tires specs. Spraying 303 Aerospace on them will also help keep them safe.
uscgcolletti
Newport News, VA
Posted: 05/08/12 01:25pm Link  |  Print  |  Notify Moderator
I keep mine in the back yard. I normally sit it right ontop treated lumber so the tires aren't in the mud if it rains.
fla-gypsy
North Florida
Posted: 05/08/12 01:32pm Link  |  Print  |  Notify Moderator
I laid a gravel driveway for mine and love how it works.
Camp Fans
North Carolina
Posted: 05/08/12 01:54pm Link  |  Print  |  Notify Moderator
Laid two strips of concrete pavers for the tires to rest on. Two 12 inch pavers laid side by side per strip. Think I used 24 total.
Camp Fans
US Air Force Retired
2004 F-250 Lariat SCrew/6.0 PSD/3.73 LSD
2012 Sabre 31 RETS
youth4him
Belgrade, MT
Posted: 05/08/12 01:55pm Link  |  Print  |  Notify Moderator
You could very easily pour some "run ways" for your tires, if you're decent at parking it. Just do 2 2'x10' by 3.5" (2x4 forms) runs, at the width of the trailer tires. Dig down to the dirt about 5", lay some gravel down and tamp it with a hand tamper, build and level the 2x4 forms, and pour.
you can buy a harbor freight mixer (I did, and have run 200+ bags through it) and bagged concrete. There are calculators or the bag will tell you how many. It'll be a lot, but cheaper than the minimum ready mix.
That all being said, I have all gravel driveway, and it works fine. You can get road mix (big rocks and dirt) and lay it down, then add smaller fines on top of it. Don't get the round stuff, it won't lock properly, I made this mistake on part of mine, and it's a bit like walking in quicksand in places.
KD
Trip of a Lifetime Blog - 12000 Miles, 100 Days, 34 States, 4 Humans, 1 Mini Daschund...FUN!
2007 GMC Yukon XL Denali - 6.2L, 6-speed
korbe
Northern California
Posted: 05/08/12 02:28pm Link  |  Print  |  Notify Moderator
Gravel is cheap. Regarding grass, it will die since you can't mow or water it.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
rfryer
Phoenix
Posted: 05/08/12 02:41pm Link  |  Print  |  Notify Moderator
I just use a couple of small pieces of treated wood to keep the tires off the ground.
