SolidAxleDurango
OK, USA
352 wrote: As I have told many. Reach your arm down the hole and feel around. If you feel anything solid squeeze it up between your fingers and wash the mess down into the holding tank. Please wash your hands thoroughly after this procedure as it can be hazardous to your heath.
I don't give a darn WHAT you say.. There is no way in hell i'm ever doing that!
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
christopherglenn
a little over an hour from Yosemite
A piece 3' piece of 3/4" pvc pipe, a 360 degree sprinkler head, shutoff valve, 3/4" hose adapter. connect them in the order listed, attach a hose, make sure nothing leaks and turn off the ****off valve (with the hose on). stand on the flush valve with the tank talves open (and hooked to a dump station). This will flush the sides of the tank semi well with almost no mess.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
nascarnutz
i'm kinda new at this indoor plumbing thing too...but i do know that if the little white door thing moves aside and you can see tp and not much liquid, add alot of water and dump it - if you have one of those fancy new-fangeled black tank rinse whatcha-ma-call-it's, even better
good luck!
Bob & Lori (BNL)
2012 Tracer 230FBS (Cupcake)
2012 Ram 1500 ST Hemi 5.7 (Smoke)
Why didn't we do this sooner ?!?!?
Ranger Goose
Tampa
thank you for all this advice. okay I'm going in... i will try everything mentioned..
and yes i can dig through poop, since i raised 3 sons nothing alarms me anymore..
I will let you know what i find, well maybe not totally.
thanks
hallock5
Ranger Goose wrote: thank you for all this advice. okay I'm going in... i will try everything mentioned..
thanks
3 sons? How long are there are arms? Round robin, flip a coin--loser takes an arm dive.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
Locky
West Michigan
Being only an hour away I am sure you are willing to go over there and show how to do this lol.
Steeljag
You guys are forcing me to drink !
2010 Flagstaff 26RLS
2012 Ford F-150 Screw Ecoboost H/D 3.73
2006 Toyota Tundra D/C (sold)
2001 Bantam B-19,(sold)
2003 Harley Road King
The whole family,
Cold ones in the cooler, good times ahead.
Locky
West Michigan
Hey Steeljag, how long of arms do you have and how far from Tampa are you?
JiminDenver
Denver, Co
I've never appreciated the fact that my hands and arms are too big to go where other peoples will as much as I do after reading this thread.
2007/2003 Ford Expedition
Nights camped in 2011 21
Nights camped in 2012 16
anaro
Mebane, NC
If you are going to do the digging thing, go to a farm supply store and get the arm length gloves vets use when putting their arm up a horse or cows rectum for an exam. This will help protect you when digging in poop.
Have you been adding extra water to the bowl when sitting and pooping? Also, use as little TP as possible and you want septic safe TP (the kind that disolves in less than a minute in a cup of water). It sounds like you have the dreaded stone mountain that needs to be busted up. As others have said, use a wand and hose it out. Just remember that water is your friend with the black tank. Once you get it cleaned out. Never ever leave the black tank empty and never every leave the black tank valve open to drain when at Full hook ups. ONce the tank is dumped, put a couple gallons water back in it.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
4 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
