RV.Net Open Roads Forum: Travel Trailers: Help! Something stuck in my toilet
 > Help! Something stuck in my toilet
phillyg
Front Royal, VA
Posted: 05/09/12 05:42am Link  |  Print  |  Notify Moderator
bpounds wrote:
If your snake went through, then water would go through too.
Well, not always. I had the same problem a couple of times last trip out. I snaked the pipe and after removing said snake, the toilet paper immediately resealed the hole the snake went through. Only solution was to push something bigger down the hole, not a nice job. My problem, and a similar one on an older Class A, is the pipe takes a 45 degree turn about 12" below the straight pipe from the toilet, and things just started to accumulate there. Best solution is to use a lot of flush water. But, that's not good if you're dry camping.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
Klueck
Posted: 05/09/12 07:36am Link  |  Print  |  Notify Moderator
hallock5 wrote:
Ranger Goose wrote:
thank you for all this advice. okay I'm going in... i will try everything mentioned..
and yes i can dig through poop, since i raised 3 sons nothing alarms me anymore..
I will let you know what i find, well maybe not totally.
thanks
3 sons? How long are there are arms? Round robin, flip a coin--loser takes an arm dive.
great (and funny) suggestion!
hilandfrog
Montana
Posted: 05/09/12 08:19am Link  |  Print  |  Notify Moderator
For a stone mountain.....
while moving our black tank, both location of tank and the holes in the tank, I did my best to clean it FIRST
There was some real "build up" of materials about 1/2" thick all across the bottom, yuck.
After pressure washing, and a few showers, is still had stuffs.
Took an orbital sander and a chunk of scrap wood, wood was held to bottom of tank, then started sanding.
It vibrated the stuff out of the tank, pretty quickly.
Might be worth a shot if other suggestions don't work.
Repo
05 Tundra 4x4
1976' SIX PAC, cut to size and function.
$800 1977' Road Ranger, not yet road worthy (AUG '11')
bpounds
Whittier CA
Posted: 05/09/12 08:37am Link  |  Print  |  Notify Moderator
You're right of course. I was thinking of the pipe between toilet and tank, which the OP was asking about with regard to something falling in the toilet. But yes, the mud pyramid will reseal around a snake.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Ranger Goose
Tampa
Posted: 05/09/12 09:37am Link  |  Print  |  Notify Moderator
THANKS TO ALL.. It worked. I put the hose down and forced the whatever through. However, the lid that opens and closes the hole in the toilet popped off and is floating around in the toilet. I can't get it out because it's too big. But I can grab it from there, I just have to figure out now how it re-attches!
smokedummy
McLennan County Texas
Posted: 05/09/12 10:12am Link  |  Print  |  Notify Moderator
Oops, now it sounds like you're going to have to remove the toilet to fix the flush valve. I might be wrong.
93Cobra2771
East Tennessee
Posted: 05/09/12 10:43am Link  |  Print  |  Notify Moderator
It is VERY easy to pull the toilet. No wax seal like at home. I had to do it one time at 12:30 in the morning when a water leak developed and I couldn't access the fittings at the back of the toilet. Good times.
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
CavemanCharlie
Storden,MN
Posted: 05/09/12 11:34am Link  |  Print  |  Notify Moderator
In the future the type of bathroom tissue that is designed for campers will help to keep the original problem from happening. It dissolves quickly and doesn't just lay in the tank in a big mound.
Now I do agree that you need to remove the toilet to fix it. Start a new thread and I'm sure the very helpful people on this site will walk you through the procedure.
bpounds
Whittier CA
Posted: 05/09/12 11:37am Link  |  Print  |  Notify Moderator
Pretty ambitious of you. I'm positive that I would turn the water off, and deal with it after breakfast.
Steeljag
Posted: 05/09/12 06:31pm Link  |  Print  |  Notify Moderator
Locky wrote:
Hey Steeljag, how long of arms do you have and how far from Tampa are you?
My arms only reach this far ! And there are no roads between here and there !
2010 Flagstaff 26RLS
2012 Ford F-150 Screw Ecoboost H/D 3.73
2006 Toyota Tundra D/C (sold)
2001 Bantam B-19,(sold)
2003 Harley Road King
The whole family,
Cold ones in the cooler, good times ahead.
