RV.Net Open Roads Forum: Truck Campers: Roof top A/C on Pop-up
 > Roof top A/C on Pop-up
oregonsteelheader
Oregon
Posted: 05/08/12 03:52pm Link  |  Print  |  Notify Moderator
I'm looking for an A/C unit for my Pop-up TC. I would like to try a roof top mounted unit, the Coleman 9000BTU is about 95 lbs. I think this may be too much weight acting as a point load on the top...Has anyone seen a roof top A/C unit on a pop-up?
If it is too much weight in one spot I'm thinking of building a roof rack and having the A/C unit actually mounted to the rack rather than the roof. This way the weight from the A/C unit will be distributed through the mounting locations of the roof rack rather than directly in one spot. I could simply build a shroud between the A/C unit and the hole in the roof...Do you think this idea has potential?
oregonsteelheader
Oregon
Posted: 05/08/12 03:57pm Link  |  Print  |  Notify Moderator
Forgot to mention that I would also add four gas struts (2 front/2 rear) 40-60lbers to help with the added weight of the rack & A/C unit when popping the top.
Hodag1
Mount Wolf, PA
Posted: 05/08/12 04:55pm Link  |  Print  |  Notify Moderator
Tell me why it is on 5 plus skids. Gotta be a big truck it came off of.
can you mount a side wall AC that you buy for $88.00 instead if an expensive roof top?
SkipJ
Michigan
Posted: 05/08/12 04:32pm Link  |  Print  |  Notify Moderator
What brand model TC? Have AC on my Outfitter
SkipJ
1992 Airstream B-190 van
1989 Airstream 25' Excella Trailer
Outfitter Apex 9.5 Truck Camper Ford F-350 Diesel 4x4
Boatycall
Tacoma, WA
Posted: 05/08/12 04:34pm Link  |  Print  |  Notify Moderator
I would first say, call the manufacturer, but I would say that second, you're fine.
I say that because I've personally worked on pop-up trailers that had roof airs on them, and I can't image those are built all that stout.
I bought one a while back off Craigslist for $250 because I wanted the roof air for my park model out at the WA coast. I pulled the roof air out, put in a vent, sealed it, and sold it for $500. It had an axle weight of under 1,000lbs.
01 F350 DRW 4x4,Torklifts,SuperHitch,F550 Rear Suspension,Roadmaster ANTI-Sway Bar,Rancho 9000s
2012 AF 1150-4 Trojans,1.5kw Inverter,32" LCD,19" LCD,Basboard heat,Dish Tailgator,Ice maker,3 awnings,80a charge circuit,Polk Audio/Kenwood/Kicker sound system
oregonsteelheader
Oregon
Posted: 05/08/12 04:43pm Link  |  Print  |  Notify Moderator
It's an old 1986 Pop up made by Four Seasons (not many made, manufacturer isnt around anymore).
Shot at 2012-05-04
It's an aluminum roof with I think 1x2 or 2x2 framing.
Boatycall
Tacoma, WA
Posted: 05/08/12 05:10pm Link  |  Print  |  Notify Moderator
Not to knock hodag, but don't do that. Looks redneck, and in a rig that size, space is at a premium.
Look on Craigslist for a cheap donor pop-up or travel trailer with a SMALL roof air on it. Take the roof air out, replace it with a $20 vent, and flip it. I ended up MAKING $250 when I did it!
As far as can it handle it, look to see what kind of framing the roof has. Pop up trailers have next-to-nothing for framing and they do fine. I would say if you have 2x2s up there, you're fine for a small roof air.
You could also just do a little reinforcing if needed. Won't take much for a small one.
Ranger Smith
Wherever the rig is parked
Posted: 05/08/12 05:28pm Link  |  Print  |  Notify Moderator
That's Redneck
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
MKish
SF
Posted: 05/08/12 05:33pm Link  |  Print  |  Notify Moderator
The wall-mount ones aren't that cheesy are they? Northstar equips some mounted in the back window at the factory.
The A-frame popup trailers usually have the ACs sticking out the side...yeah maybe the roof does look better. But that 4 Seasons is so wonderfully sleek and low-profile it would almost be a shame to put anything on the roof!
Hodag1
Mount Wolf, PA
Posted: 05/08/12 06:01pm Link  |  Print  |  Notify Moderator
Boatycall,
Thanks for the redneck complement! I wish I had a wall mount heat pump in my Outfitter instead of the roof mount AC and wall mount propane furnace.
