TxTiger
North Texas
I have a 2011 KZ Sportsmen toy hauler and I plan to clean and UV treat the roof this month, along with a good waxing on the walls. Would it be advisable as a proactive measure to apply Eternabond tape to the various seams in the roof while the caulking is still in good shape? It seems as if it will have to be done at some point, and I'm just thinking it would be easier before I have to remove old caulking and go through issues associated with a roof leak.
2000 F250, 7.3 PSD, 6 speed manual, CC, SB
KZ 27TH Toy Hauler, 5,700 lb dry weight/8,000 lb GVW.
2010 Triumph Tiger 1050
2012 Triumph America
2009 Suzuki DRZ 400sm
tvman44
Southwest Louisiana
Very good idea, I am in the process of doing just that.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
We Cant Wait
Jamestown NY
I'm doing the eternabond PM to my trl roof this weekend. The skylight, vents, front & rear seams, and the roof edge front to rear on both sides. I do the roof edges after having scraped a tree branch on the roof edge and getting a hole in the roof.
Klueck
Absolutely! If you do it now, you will never have to re-seal or worry about any roof leaks. I wish we had known about Eternabond on our first motorhome.
stitchinsue
Central Pa
Do you have to scrape the caulk off or do you apply it over the caulk?
rgolding
Southern Illinois
I have done the same thing using the Dicor 4 inch by 50 ft roll of tape. I called tech support at Dicor and they said get it clean and wipe the surface down with rubbibg alcohol before installation right over Dicor caulking. Feel it was a good peace of mind upgrade.
john b
anywhere USA!
Klueck wrote: Absolutely! If you do it now, you will never have to re-seal or worry about any roof leaks. I wish we had known about Eternabond on our first motorhome.
Xx2!
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2011 Crossroads Cruiser cf32mk Patriot edit. 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
McDaddy
Saugus, Ma
You do not have to scrape the old caulking off prior to applying the eternabond tape. This is specified on their website. You do need to clean the area around it to get good adhesion. I did mine this weekend. I first washed the entire roof and rinsed it really well. Then I let it dry for a day. Then I cleaned around each seam using the spray cleaner that I purchased from eternabond. I then applied the tape following their instructions. I am very happy with the way it turned out.
TxTiger
North Texas
So I checked out Eternabond's website, and I think the standard roofseal tape apperars to be the one to get. I notice they have it in numerous widths, starting at 2". I would think 4" would be about the right width. What are opinions about the width?
BarneyS
S.E. Lower Michigan
The 4" will be just right. I did my trailer about 7 years ago when it was still just about new. I went right over the caulking.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
