RV.Net Open Roads Forum: Tow Vehicles: You're not going to believe this...
Search only in Tow Vehicles
 > You're not going to believe this...
blt2ski
Kirkland, Wa
Posted: 05/08/12 08:59pm Link  |  Print  |  Notify Moderator
donn0128 wrote:
Turtle n Peeps wrote:
The Ally baby!!! You know the one they put in tanks!
OH come on get real. THEY DO NOT INSTALL THE ALLISON 1000 IN TANK! I thought that fallacy was long put to bed. The Allison 1000 as I remember is only rated to handle something like 850lbFt and 26000 GCW.
ANd when the 1000 first came out, it was rated to a whopping 550 lb ft of torque! But it is an ally put in a tank! so must be good!.......yeah right
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
Turtle n Peeps
California
Posted: 05/08/12 09:02pm Link  |  Print  |  Notify Moderator
Really? Are you serious? Wow? And here I thought the would be a dead giveaway. Here is another to double up.
Maybe it was the Powerglide I was thinking of they put in tanks?
Yep, it was the Powerglide!!
By the way. Did you know Ford owns Cummins?
outside the fire"
JPhelps
SE of Monkeys Eyebrow & Possum Trot
Posted: 05/08/12 09:10pm Link  |  Print  |  Notify Moderator
Everyone knows that. They have for years. Old news......... Seriously.
blt2ski
Kirkland, Wa
Posted: 05/08/12 09:19pm Link  |  Print  |  Notify Moderator
NO NO NO....
Ford owns CUMMNGS, we all know there is no such arnimal as a cummins!..........
#40Fan
Colorado
Posted: 05/08/12 09:43pm Link  |  Print  |  Notify Moderator
Ford doesn't own Cummins, Cummings or a real diesel.
2013 Arctic Fox 22GQ
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
Engineer9860
Eagle Scout dad
Posted: 05/09/12 06:05am Link  |  Print  |  Notify Moderator
In Memoriam: Liberty Belle
NavyDood
NW of DFW
Posted: 05/09/12 06:43am Link  |  Print  |  Notify Moderator
Absolutely retarded IMO. The amount of money that needs to be put into an Undurablemax to make that kind of power is easily twice the price of what that 2001 truck was new. All for what... bragging rights and a feature in a magazine?
- Retired Navy Chief
- Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter
- 06 Pilgrim 30RE2SLF-5 13,300lbs loaded. B&W Companion
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/09/12 07:23am Link  |  Print  |  Notify Moderator
3020 lb/ft of torque at the rear wheels is no big deal. A stock 800 lb/ft engine running in direct gear in the transmission with 4.10 axle gearing puts 3200 lb/ft torque to the rear wheels when running at an engine rpm coinciding with the max torque output of the engine.
Now 1600 horsepower at the rear wheels, that truly is something to write home about!
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
ib516
Up here!
Posted: 05/09/12 08:40am Link  |  Print  |  Notify Moderator
IIRC, the newest crop of 800 tq rated diesels put something like 650 tq to the wheels as measured on a chassis dyno. - Apples to apples.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Engineer9860
Eagle Scout dad
Posted: 05/09/12 10:41am Link  |  Print  |  Notify Moderator
At those power levels I hardly think you could call a Duramax "undurable".
As far as it being "retarded"....... Different strokes for different folks. I'm quite sure there are things about you that somebody might find to be "retarded"....... Starting with your opinion.
