RV.Net Open Roads Forum: Travel Trailers: rusted staples in ceiling
 > rusted staples in ceiling
jldb4jlk
Vermon
Posted: 05/08/12 07:11pm Link  |  Print  |  Notify Moderator
I have a 2009 Keystone Passport that I purchased new two summers ago. Last weekend I noticed that there was something yellow on the ceiling of the RV. The closer I looked there were little marks where the staples were in the ceiling and the paint was coming off them. They look rusted. The closer I looked there are yellow lines all the way down the whole length of the camper that go across width wise on the camper. It is every foot and a half or so where they stapled the ceiling to the beams. Other then the marks in a line along the beams there are no other marks on the ceiling anywhere.
All of the seals on the roof look fine. The dealership(which is closer to my house then where I bought it), has told me to contact my insurance company and the manufacturer and see what they could do for me.
If I missed a seal that is leaking then I am willing to accept that but I just cant see where the moisture is coming from.
The theories I have heard so far:
-leak in roof
-beams might not have been completely dry when they put the camper together
-glue is making the marks in the ceiling
Any advice would be appreciated.
nascarnutz
Posted: 05/08/12 07:28pm Link  |  Print  |  Notify Moderator
i would suggest grabbing a strong beamed flash light on a sunny day and seeing what you can see around the bottom side of the ac housing on the roof - it may not get a lot of sun, but it can build up dirt and debris which may cause even the smallest of stuff to grow and separate seams
Bob & Lori (BNL)
2012 Tracer 230FBS (Cupcake)
2012 Ram 1500 ST Hemi 5.7 (Smoke)
Why didn't we do this sooner ?!?!?
ScottG
Bothell Wa.
Posted: 05/08/12 07:39pm Link  |  Print  |  Notify Moderator
I have no leaks either but just noticed a few of those are rusted slightly on my TT as well. I believe it's just from condensation, especially when we're sleeping. The ceiling definitely gets sweaty during the night hours.
I plan on using just a dab of white caulk to hide them.
* This post was edited 05/08/12 07:57pm by ScottG *
Scott, Grace and Wesly
H0NDA eu2000i
jldb4jlk
Vermon
Posted: 05/08/12 08:11pm Link  |  Print  |  Notify Moderator
Thanks for the ideas, I will check around the AC. As soon as I figure out why it is doing it I am sure I will have to remove the rusted staples and put in some new ones and painting is going to be the only thing that will cover it up the yellow lines, they are about 2 inches wide and go all the way across the ceiling. I was going to look around for a place that would do a pressure test for me to help find a leak if there is one. I didn't leave a window open this winter and I am wondering if moisture built up in the camper and that is what did it.
dodge guy
Bartlett IL
It`s just moisture in the air. that will make the staples rust.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
jldb4jlk
Vermon
Posted: 05/08/12 08:23pm Link  |  Print  |  Notify Moderator
Dodge Guy: What would make the yellow lines the residue from the staples?
dodge guy
Bartlett IL
Posted: 05/09/12 05:04am Link  |  Print  |  Notify Moderator
It could be the filler they use to cover the staples? maybe? It sounds like it`s the way they built it.
Wills250psd
walnutcove NC
Posted: 05/09/12 05:14am Link  |  Print  |  Notify Moderator
Some Rv's have glue between the cieling and rafters maybe it bleeding through?
boosTT
Milwaukee
Posted: 05/09/12 06:53am Link  |  Print  |  Notify Moderator
I've just gotten this same issue in my 2005 Keystone. It was moist in there this winter... I suspect its from the moisture. I cought it before it got too bad though. Actually, you can't even see it unless you use a flashlight pointed at the spots.
I have no plans to "repair" this issue.
uscgcolletti
Newport News, VA
Posted: 05/09/12 07:09am Link  |  Print  |  Notify Moderator
+1
