shasta24
home
Im learning much about rebuilding my shasta. I have another burning question for you good people. I purchased a corragated underbelly material from a company,and started install. Are you serious,I had to ask myself. Is this material going to keep the bottom of my tt dry? Much less offer any road damage protection? It looks like painted cardboard. THe company says this material is used on new tt.
bob213
Fresno, CA
I think it makes your TT more aerodynamic, helps to keep varmits out, gives you the ability to have some insulation and cover it up. I do think it will help to keep it dry and protect it from road salts and debris. On my last trailer, after 4 years, I saw no noticeable wear or damage.
downtheroad
Pacific Northwest
If the material is Coroplast , then yes..
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
SabreCanuck
Winnipeg
I've thought the exact same thing... looks like painted cardboard.
Bit Bucket
Brookings, Oregon
Yes it is cheap, but fairly good at what it is for. If it provides some degree of insulation value by keeping the breeze from directly contacting the real underbelly of your TT and provides an additional partial barier from rodents and pests and stops the road water, etc. from directly contacting the underbelly as well as providing a place to stuff some extra insulation around your tanks then it is worth it in my opinion...
It is also easy to seal with spray foam and Gorilla tape or equivalent.
Chad/Jen
Where might I get this stuff? Is it ordered online or would it be better to get it from an RV supply place dealer locally?
tfodify
Winnipeg
Clear coroplast has been used in sunrooms for many years. If I were putting this stuff on a trailer, I think that's what I'd choose. It'd be much easier to tell if any rodents had made their way in.
shasta24
home
It seems that some of you have the underbelly that is the lowest part of your tt. The underbelly on my tt is laying on top of the metal frame. Then the subfloor sits on that.My tanks are not even covered be the underbelly. Im thinking now of going ahead and closing the whole darn thing in the best I can.
93Cobra2771
East Tennessee
Clear coroplast? Hmm, that would be interesting. Would be an easy way to see if you had a leak or not, that's for sure.
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
Bit Bucket
Brookings, Oregon
shasta24 wrote: It seems that some of you have the underbelly that is the lowest part of your tt. The underbelly on my tt is laying on top of the metal frame. Then the subfloor sits on that.My tanks are not even covered be the underbelly. Im thinking now of going ahead and closing the whole darn thing in the best I can.
The "under belly" is the additional barrier attached near the bottom of the frame, it is always the lowest part of the trailer. You are seeing the bottom layer of your floor. A lot of trailers don't come with an under belly, it is an additional barrier, in your case it doesn't sound like you have an "under belly".
