RV.Net Open Roads Forum: Class A Motorhomes: Brake Inspection Areas prior to grades?
 > Brake Inspection Areas prior to grades?
supercub
Modesto CA
Posted: 05/08/12 09:13pm Link  |  Print  |  Notify Moderator
I'm curious what the truckers check. I know the brakes!.......What specifically do they check? Can they see the brake pads?
Brian
sgip2000
Oregon
Posted: 05/08/12 09:43pm Link  |  Print  |  Notify Moderator
They normally check for heat build up and to let their air tanks build pressure back up. Proper air pressure is necessary with air brakes.
Stranger
Sparks, NV. USA
Posted: 05/08/12 09:45pm Link  |  Print  |  Notify Moderator
Yes, they can see the shoes and the amount of material left. Providing they get UNDER the trailer or truck.
It is also possible for them to adjust their brakes if there is too much travel.
Hope this helps.
Life is not a journey to the grave with the intention of arriving
safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting "Wow, what a ride!".
2002 3500 6 Speed
2005 ALFA
Just 72 feet!
Executive
Posted: 05/08/12 10:04pm Link  |  Print  |  Notify Moderator
Can't vouch for the truckers, but I check the toad and all connections. I also do a walk around, checking compartment doors, tires, make sure the tow bar is tight, look at the toad tires and the brake cables from the ReadyBrake....walk the dog, use the bathroom and I'm good to go..last place I want surprises is half way down a hill....just sayin...Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
trike2
idaho
Posted: 05/08/12 10:06pm Link  |  Print  |  Notify Moderator
Among the above mentioned, they also have other things to do, like take a hammer, and check the tire, if it bounces back the tire is good, Also if you see them on the road side edge too long, don't look.
2005 gmc 3/4 hd, sb, 4x4, 8.1 gas/allison 17,000 and climbing.
2005 Lakota, by Monaco, 3 slds, 29f.
W4RLR
Sewanee, Tennessee
Posted: 05/08/12 11:41pm Link  |  Print  |  Notify Moderator
Double post.
* This post was edited 05/09/12 11:05pm by W4RLR *
Richard L. Ray
SSgt USAF (Retired) Life Member DAV
W4RLR 146.52 mhz
2005 Ford F-250 Lariat Crew Cab
1995 Jayco Eagle 277RBSS fifth-wheel
"Never ask a man what kind of computer he drives. If it's a Mac, he'll tell you. If not, why embarrass him?"
Tom Clancy
Jim & Betty
Brandon, South Dakota
Posted: 05/08/12 11:46pm Link  |  Print  |  Notify Moderator
They are checking the slack adjustment and over all condition of the rig tires, air hoses and such..
JimR
moisheh
North America
Posted: 05/09/12 04:44am Link  |  Print  |  Notify Moderator
They are supposed to do a complete air brake check. Tractor service brakes, trailer service brakes, tractor spring brakes. Compressor load and unload test,low pressure warning devices and more. If a trucker has to stop to build up air he has some serious problems. The drums and shoes should have been checked in the morning when he did a complete pre trip and air brake test. If the truck brakes have been performing well they often will just do the tug test. Some do almost nothing!
Moisheh
LoneCowboy
Colorado
Posted: 05/09/12 05:53am Link  |  Print  |  Notify Moderator
Yes, on Class 8 trucks you can see the brake shoes.
They are also checking adjustment. It's not such a big deal on adjustment anymore, but until about the mid 90's, you had to manually adjust the brakes, now they auto-adjust (or are supposed to anyway).
LoneCowboy
Colorado
Posted: 05/09/12 05:58am Link  |  Print  |  Notify Moderator
W4RLR wrote:
I find on my own rig that I can just drop down to second gear, take my foot off the go pedal and let engine braking and gravity do the work, while I'm maintaining a 55-60 mph speed. To me it's 4 miles of downhill fun.
that's great
but it doesn't work in a semi-truck.
The weight is simply too much, you can actually over-speed the engine thru the mechanical forces working on it.
Diesel engines don't engine brake like gas engines do, that's why they invented engine brakes ( Jake Brakes is the common one) which forces engine back pressure. You can still over-speed it even with the engine brakes full on if you are heavy enough (or the brake is weak enough).
Comparing a pickup truck with a trailer to even an empty semi-truck is silly. Until you drive a semi, you simply cannot understand the forces working on it. The weight is overwhelming. Even a unloaded light semi and trailer weighs more than your entire rig. Then they add another 50,000 pounds of weight.
